[GeoNetwork-users] How to encode dataseries!
I have a geological map of Tuscany region. This map is divided in about 700
tiles developed by different authors.
Is it possible to manage the shared metadata information in a parent
dataseries?
And the 700 tile as dataset?
If this is possible when a user will search for a shared metadata, retrieve
all 700 tiles or first the parent dataseries and then the tiles?
Thanks in advance
Andrea, did you find an answer ?
I'm in a similar case, where i would like to gather some elements of data
inside of a data series.
In my case, the best scenario would be to ba bale to search first amongst
the data series, and when we find an interesting data series, to be able to
list the linked data elements.
Is it possible ? How ?
Thanks
Jean
2009/5/7 Andrea Cappugi <kappu@anonymised.com>
dataseries?
Thanks in advance
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
GeoNetwork-users mailing list
Hi Jean
I'm still searching the answer.
Ciao
On Fri, May 15, 2009 at 10:56 AM, Jean Pommier (IGE) <jean.pommier@anonymised.com>wrote:
Thanks
Jean
700
dataseries?
retrieve
Thanks in advance
i700
