[GeoNetwork-users] How to encode dataseries!
Andrea,
The DS_Series adds lots of baggage to the system so I would suggest using it only when definitely required. The case you describe, a map made up of tiles, might be more easily described as a single dataset with multiple sources in the DQ_DataQuality section. Each tile is a source that has it's own citation and, more importantly, it's own extent (the extent of the tile). I think that is all you need.
BTW, we are working with many datasets like this and are exploring a practice of naming the extent referenced in MD_DataInformation as fileidentifier.boundingExtent. An extent with this name would be understood to be the complete extent for a dataset and would be the one cross-walked to standards that only allow one extent (i.e. FGDC) and searched first. More detailed extents could be included with appropriate names.
In NOAA, the NOS Physical Oceanographic Real-Time System PORTS® <http://tidesandcurrents.noaa.gov/ports.html&gt; is a decision support tool that improves the safety and efficiency of maritime commerce and coastal resource management through the integration of real-time environmental observations, forecasts and other geospatial information from a number of important commercial ports in the United States. These ports are in disjoint regions from Tampa to Anchorage along the east and west coasts of the United States. The map attached shows these regions as small red boxes which were extracted from the NOSA database for the PORTS observing system. The large box is the bounding lat/lon box of the entire collection. The XML for this case looks like the snippet included below.
Hope this seems reasonable. Please let me know if you have questions,
Ted
  <gmd:extent>
   <gmd:EX_Extent uuid="gov.noaa.nosa:NOS-PORTS.boundingExtent'">
   <gmd:description><gco:CharacterString>gov.noaa.nosa:NOS-PORTS.boundingExtent</gco:CharacterString></gmd:description>
    <gmd:geographicElement>
     <gmd:EX_GeographicBoundingBox>
      <gmd:westBoundLongitude><gco:Decimal>-151.3959</gco:Decimal></gmd:westBoundLongitude>
      <gmd:eastBoundLongitude><gco:Decimal>-71.1818</gco:Decimal></gmd:eastBoundLongitude>
      <gmd:southBoundLatitude><gco:Decimal>27.5697</gco:Decimal></gmd:southBoundLatitude>
      <gmd:northBoundLatitude><gco:Decimal>61.2255</gco:Decimal></gmd:northBoundLatitude>
     </gmd:EX_GeographicBoundingBox>
    </gmd:geographicElement>
  </gmd:EX_Extent>
  </gmd:extent>
  <gmd:extent>
   <gmd:EX_Extent uuid="Anchorage PORTS">
    <gmd:description><gco:CharacterString>Anchorage PORTS</gco:CharacterString></gmd:description>
      <gmd:eastBoundLongitude><gco:Decimal>-149.8981</gco:Decimal></gmd:eastBoundLongitude>
      <gmd:southBoundLatitude><gco:Decimal>60.6845</gco:Decimal></gmd:southBoundLatitude>
   </gmd:EX_Extent>
  </gmd:extent>
  <gmd:extent>
   <gmd:EX_Extent uuid="Chesapeake Bay PORTS">
    <gmd:description><gco:CharacterString>Chesapeake Bay PORTS</gco:CharacterString></gmd:description>
      <gmd:westBoundLongitude><gco:Decimal>-77.0208</gco:Decimal></gmd:westBoundLongitude>
      <gmd:eastBoundLongitude><gco:Decimal>-75.5631</gco:Decimal></gmd:eastBoundLongitude>
      <gmd:southBoundLatitude><gco:Decimal>36.7793</gco:Decimal></gmd:southBoundLatitude>
      <gmd:northBoundLatitude><gco:Decimal>39.5619</gco:Decimal></gmd:northBoundLatitude>
   </gmd:EX_Extent>
  </gmd:extent>
==== Ted Habermann ===========================
     Enterprise Data Systems Group Leader
     NOAA, National Geophysical Data Center
     V: 303.497.6472 F: 303.497.6513
     "If you want to go quickly, go alone.
     If you want to go far, go together"
     Old Proverb
==== Ted.Habermann@anonymised.com ==================
(attachments)
Hi Ted,
thanks for your answer and sorry for the delay in mine, I was out of office
untill today!
I agree that the case is more like a single dataset with multiple source,
but in this case the multilple sources differ for the extent and the Author.
How can i add in data quality info the Authir information for each tile?
Thanks in advance
On Tue, May 19, 2009 at 4:49 PM, Ted Habermann <Ted.Habermann@anonymised.com>wrote:
Andrea,
Ted
<gmd:extent>
</gmd:EX_Extent>
</gmd:extent>
<gmd:extent>
</gmd:EX_Extent>
</gmd:extent>
<gmd:extent>
</gmd:EX_Extent>
</gmd:extent>
   Old Proverb
Andrea,
I don't think this is going to be a problem. The ISO DQ_DataQuality class has three pieces: scope, lineage, and reports. In my previous answer I suggested describing the extent in the sourceExtent. You can move that description up to the DQ_DataQuality/scope/DQ_Scope/extent and it would cover the whole DQ_DataQuality section: the lineage (with the citation to the author), and whatever quality reports might be available for that tile. This means that you will end up with a DQ_DataQuality section for each tile. Those sections would look sort of like
<DQ_DataQuality>
    <scope> this is where the extent is described
    <lineage> This is where the source is described including a citation to the author
    <report> This is where the quality information goes.
</DQ_DataQuality>
The standard allows multiple DQ_DataQuality sections, a single scope/section, and multiple reports/section, which fits this approach very well.
This case demonstrates nicely the benefits of thinking about ISO metadata as a collection of related objects rather than as a single metadata record. You will end up slapping all of these objects together in a single file, or in response to a single request, but they are really a searchable collection of spatial (and possibly temporal) objects that could be presented well in an interactive map that provided source and quality information.
Sounds like fun!
Ted
Andrea Cappugi wrote:
Hi Ted,
thanks for your answer and sorry for the delay in mine, I was out of office untill today!
I agree that the case is more like a single dataset with multiple source, but in this case the multilple sources differ for the extent and the Author. How can i add in data quality info the Authir information for each tile?
Thanks in advance
On Tue, May 19, 2009 at 4:49 PM, Ted Habermann <Ted.Habermann@anonymised.com <mailto:Ted.Habermann@anonymised.com>> wrote:
    Andrea,
    included below.
    Ted
     <gmd:extent>
     </gmd:EX_Extent>
     </gmd:extent>
     <gmd:extent>
     </gmd:EX_Extent>
     </gmd:extent>
     <gmd:extent>
     </gmd:EX_Extent>
     </gmd:extent>
    -- ==== Ted Habermann ===========================
       Old Proverb
    ==== Ted.Habermann@anonymised.com <mailto:Ted.Habermann@anonymised.com>
     Old Proverb
