[GeoNetwork-users] How to import a Spot dimap metadata (.DIM) to geonetwork
Does someone knows how to convert .dim metadata to metadata format that
geonetwork could handle? Maybe using gdal?
No idea what a .dim metadata looks like :slight_smile:
You could write an XSLT that takes a dim as input and generates a valid ISO19115/19139 metadata record. You can use such an XSLT in the different insert/ import services available.
Ciao,
Jeroen
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi
Jeroen Ticheler wrote:
http://www.spotimage.fr/dimap/spec/documentation/4.Dimap_in_use.htm
more ore less a complex MEF :slight_smile:
Jeroen is right, an XSLT should be quite easy to use to extract info
from the dimap file. It seems that it has been used to create html :
"Using XML (Dimap documents) and XSL style sheets, a data producer can
get its products behave as if they were plain HTML files to the end user."
Francois
Ciao,
Jeroen
that
browser.
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
francois-xavier.prunayre@anonymised.com
