Hi Linde,
We are also working on this. As far as I understand the ESRI help (...) the
url to an ArcGIS Server WMS should be:
http://<SERVERNAME:port>/arcgis/services/<IF USED
FOLDERNAME>/<SERVICENAME>/MapServer/WMSServer?
REQUEST=GetCatabilities&SERVICE=wms
Any luck?
Johan
Netherlands Environmental Assessment Agency (PBL)
Information Services and Methodology (IMP)
E: johan.meijer@anonymised.com
W: www.planbureauvoordeleefomgeving.nl
T: +31 30 274 4390
F: +31 30 274 4427
Postbus 303
3720 AH Bilthoven, the Netherlands
Jeroen Ticheler
<Jeroen.Ticheler@
geocat.net> To
Linde Ackermans
01/30/2009 02:07 <roselinda.ackermans@anonymised.com>
PM cc
geonetwork-users@anonymised.com
net
Subject
[Spam] Re: [GeoNetwork-users] How
to integrate ArcGis Server 9.3 WMS
services with Intermap ?
Hi Linde,
Did you try to issue a GetCapabilities request to that URL?
Something like:
http://servername:8399/arcgis/wms?REQUEST=GetCatabilities&VERSION=1.1.1
&SERVICE=wms
If that works, the same layers should appear in the list in InterMap.
If your ArcGIS server is publicly accessible I could have a look at it
directly. I know that ArcIMS used to have a slightly different concept
of WMS services. It would basiaclly require you to connect to it using
something like http://servername:8399/arcgis/wms/NAMEOFTHELAYER?…
Ciao,
Jeroen
On Jan 30, 2009, at 12:07 PM, Linde Ackermans wrote:
Hello,
I installed Geonetwork 2.2 on a Solaris 9. The Intermap viewer is
loading OK
with the default map service.
(gn:world and gn:boundaries)
Now I want to add a ArcGIS Server 9.3 and its services.
In <geonetwork_install_dir>/web/intermap/mapServers.xml , I added
this :
<server type="2" name="ArcGIS Server 9.3">
<url>http://servername:8399/arcgis/wms</url>
</server>
The server name shows up in the list when using "Add layer" in
Intermap, but
clicking this entry does not show the available services. What is the
correct syntax ??
And what about the <mapContexts> ? What is it used for ? Is there any
documentation on how mapServers.xml is organized ?
Thanks!
Linde
View this message in context:
http://n2.nabble.com/How-to-integrate-ArcGis-Server-9.3-WMS-services-with-Intermap---tp2244261p2244261.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
GeoNetwork-users mailing list
