hi all,
second attempt. i think the migration of metadata is important for more people than me so i don't give up. i appreciate every help, e.g. a hint for a tutorial, short descriptions, how other people manage this problem, concrete hints for importing metadata with the batch import of geonetwork, workarounds, ...
there are at least three use cases:
use case 1: migration of metadata from instance 1 to instance 2 of geonetwork using the same database
solution: export and import the data with database-tools, e.g. druid
problem: druid doesn't export the field which contains the xml-data
use case 2: migration of metadata from instance 1 to instance 2 of geonetwork using another database
solution: exporting the metadata with geonetwork or a database-tools, e.g. druid, importing the metadata with geonetwork batch import
problem: is there a possibility to export metadata with geonetwork, druid doesn't export the field which contains the xml-data
use case 3: migration of metadata from another source or a incompatible geonetwork version
solution: XML Metadata Insert or Batch Import with geonetwork
problem: i get a lot of constraints violations, also with metadata which are created by geonetwork (see below)
thanks and greetings from munich
christian
Von: geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] Im Auftrag von Christian.Strobl@anonymised.com
Gesendet: Dienstag, 29. Mai 2007 16:55
An: geonetwork-users@lists.sourceforge.net
Betreff: [GeoNetwork-users] how to: metadata migration
hi all,
first of all, i like geonetwork. it's a great tool for exploring metadata and finding data.
next to my problem: what is the best way for migrating metadata sets from one geonetwork instance to another.
i tried to copy metadata sets from the xml-view and to paste it (exactly the same metadata) with XML metadata insert. i get errors like
Error on line 64: The reference to entity "fname" must end with the ';'
delimiter.
Error on line 268: The content of elements must consist of well-formed character data or markup.
Immediate unique constraint violation (_ANONYMOUS_CONSTRAINT_8) Columns = ( uuid ) Table = ( APP.Metadata )
if i am correcting all the errors the import works but with a lot of manual work. thats not possible for a lot of data.
if i am trying the batch import i get always the same message which i don't understand
The requested operation could not be performed.
Error on line 1 of document file:/home/christian/test/: Content is not allowed in prolog.
any help appreciated, thanks and greetings from munich christian
p.s. maybe there is a tutorial or howto for metadata importing, but i didn't find it yet
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
