[GeoNetwork-users] how to remove social share buttons?
Hi
looking to remove the social share buttons from our instance of geonetwork, where is this config set?
I've found sharing is referenced in these files but not sure if correct place to modify
catalog/components/common/share/
catalog/views/default/templates/recordView.html
Thanks
GIS TEAM
Limerick City and County Council
Email gis@anonymised.com
Limerick ....One of the 'TOP 10 PLACES TO INVEST IN EUROPE'- 6th Global Best to Invest Report, Site Selection Magazine Limerick City & County Council Disclaimer: This electronic message contains information (and may contain files), which may be privileged or confidential. The information is intended to be for the sole use of the individual(s) or entity named above. If you are not the intended recipient be aware that any disclosure, copying, distribution or use of the contents of this information and or files is prohibited. If you have received this electronic message in error, please notify the sender immediately. This is also to certify that this mail has been scanned for viruses. Tá eolas sa teachtaireacht leictreonach seo (agus b'fhéidir sa chomhaid ceangailte leis) a d'fhéadfadh bheith príobháideach nó faoi rún. Is le h-aghaidh an duine/na ndaoine nó le h-aghaidh an aonáin atá ainmnithe thuas agus le haghaidh an duine/na ndaoine sin amháin atá an t-eolas. Murab ionann tusa agus an té a bhfuil an teachtaireacht ceaptha dó bíodh a fhios agat nach gceadaítear nochtadh, cóipeáil, scaipeadh nó úsáid an eolais agus/nó an chomhaid seo. Más trí earráid a fuair tú an teachtaireacht leictreonach seo cuir, más é do thoil é, an té ar sheol an teachtaireacht ar an eolas láithreach. Deimhnítear leis seo freisin nár aimseodh víreas sa phost seo tar éis a scanadh. [http://www.limerick.ie/sites/default/files/thumbnails/image/investinlimerick.png\]
