Deal all,
I am unable to log on with the admin account to a certain GeoNetwork
instance, but I do not recall ever changing the password. How can reset (or
change) the admin password without logging on to the web interface?
Thank you.
Deal all,
Thank you.
An option is to update the password column in the user table from the db
creation script
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-default.sql#L655(use
the one from the version you're using).
Cheers.
Francois
2014-04-29 15:14 GMT+02:00 Luís de Sousa <luis.a.de.sousa@anonymised.com>:
Deal all,
change) the admin password without logging on to the web interface?Thank you.
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
GeoNetwork-users mailing list
Hi François, that seems to be a possible fix, but how do I connect to the
database?
Thanks.
On 29 April 2014 15:31, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
creation scripthttps://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-default.sql#L655(use the one from the version you're using).
Cheers.
Francois
Deal all,
(or
available.
After restarting the service I am able to log on again. Hat tip <a href="
http://gis.stackexchange.com/questions/94594/geonetwork-how-to-reset-the-admin-password">nmtoken
at GIS.SE</a>.
Regards.
On 29 April 2014 16:01, Luís de Sousa <luis.a.de.sousa@anonymised.com> wrote:
database?Thanks.
Cheers.
Francois
Deal all,
(or
available.
