[GeoNetwork-users] Html5ui and "Link to a parent" popup, scrollbar not visible
hello
Using a GN 2.10.2, with html5ui interface
When i edit a metadata in ordre to link to a parent metadata, a popup appears.
A list of existing metadata should be shown, but the window only shows half part of the first metadata
The vertical scroll bar isn't available.
Thus i can only select the first line, which is not very user friendly ...
Does anybody solved this issue ?
Re: Publication profil geonetwork Philippe
Hi Philippe
This is related to this issue:
https://github.com/geonetwork/core-geonetwork/issues/358
I could not work in a fix yet.
Jose GarcĂ­a
On Fri, Mar 28, 2014 at 10:28 AM, Philippe Clastre <
Philippe.Clastre@anonymised.com> wrote:
hello
appears.
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcĂ­aGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
