Hi, a short question :
- let's activate ssl secure connections - logged in as admin (GN version
3.2.x)
- by a chance we mess up something during the tomcat ssl configuration or
elsewhere and receive "Service Unavailable" response while accessing
geonetwork url.
Which config file should we edit to reverse back to http protocol ?
Hoping there's a simple answer for that.
Sub-question : If ssl is "on", the site is not accessible via port 80
and the other way around, right ?
thnx !
View this message in context: http://osgeo-org.1560.x6.nabble.com/Https-preferred-protocol-configuration-via-admin-UI-How-to-switch-back-to-default-http-tp5326556.html
Hi
The protocol/port configuration in GeoNetwork is used for the urls returned
in html code (javascript, css, images) and links in metadata to thumbnails,
files.
But the protocols allowed to access your site are controlled by Tomcat or
Apache Web Server (or other web server you can use). If you can not access
by http to the site it's not related to the configuration done in
GeoNetwork, you need to check Tomcat or Apache Web Server configuration.
Jose García
3.2.x)
geonetwork url.
thnx !
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
