[GeoNetwork-users] https support
Hi list,
I've got to install GeoNetwork in a https only environment, but when I was
looking in the source code, I've came across some hardcoded http addresses.
Examples of this are:
SettingInfo.java (line 80)
DataManager.java (line 903 and 2902)
XmlResolver.java (line 73 and 74) (in jeeves.utils)
But also in the following (and perhaps more) xsl files:
metadata-iso19115.xsl
metadata-iso19139.xsl
header.xsl
kml.xsl
metadata-show-embedded.xsl
metadata-show.xsl
portal-sitemap.xsl
search-suggestions.xsl
Does anyone have experience in setting up GeoNetwork in a https-only
enviroment, and have these hardcoded http values any influence on the
interaction with the different services?
Thanks in advance,
Wouter
Wouter
http://blog.giswhat.be
