Hello everybody working with GeoNetwork on weekends:clap:
I dont know if I have the expected skills to install GeoNetwork. I have been
working with computers since 1974 but I know very little about localhost,
Java, webservices from a computer technicans point of view. I have a Master
Degree in surveying. If you think that this is something witch I should let
somebody more skilled do this job. please let me know. Hopefully the intent
is to let everybody interested beiing able to use this wonderful FOSS. I´ve
tried http://apps.who.int/geonetwork/srv/en/main.home and
http://www.fao.org/geonetwork/srv/en/main.home and it looks VERY GOOD!
HERE IS MY PROBLEM:
Trying GeoNetwork on my Dell T7400 workstation still gives me the
"HTTP ERROR: 404 NOT_FOUND RequestURI=/geonetwork/srv/en/main.home Powered
by jetty://" message.
Just for "fun" I tried to install GeoNetwork on my second desktop Dell
Dimension 8200 and surprise, surprise- this time GeoNetwork stopped after at
least showing the http://localhost:8080/geonetwork/srv/en/main.home
webscreen. Both computers are running the same environment, Windows XP IE8
etc.
The What? Where? Search part in the upper left corner shows a moving square
all the time and the Windows timeglass are shown when I move the cursor to
that part of the window.
I get the following messages from IE8 in the lower left part of the window:
"Something wrong with this webside". I´ve logged in as admin admin. Looking
at the details in the errormessage it says:
Useragent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0;
GTB6; .NET CLR 1.1.4322)
Timestamp: Sat, 26 Sep 2009 06:25:28 UTC
Message: Expected identifier, string or number
Row: 97
Character: 4
Code: 0
URI: http://localhost:8080/geonetwork/srv/en/user.login
Meddelande: 'Env' is undefined
Rad: 16
Tecken: 2
Kod: 0
URI: http://localhost:8080/geonetwork/scripts/core/kernel/kernel.js?
Rad: 16
Tecken: 2
Kod: 0
Rad: 146
Tecken: 5
Kod: 0
It seems like I´m getting closer, but i can´t find the 'Env' parameter. If
you are able to understand my problem, please give me a push forward.
Regards Anders Söderman Sweden
Here is the log without the timestamps.
INFO [jeeves.engine] - === Starting system
INFO [jeeves.engine] - Java version : 14.1-b02
INFO [jeeves.engine] - Java vendor : Sun Microsystems Inc.
INFO [jeeves.engine] - XSLT factory : net.sf.saxon.IdentityTransformer
INFO [jeeves.engine] - Path : C:\Program\geonetwork\web\geonetwork/
INFO [jeeves.engine] - BaseURL : geonetwork
INFO [jeeves.engine] - Loading :
C:\Program\geonetwork\web\geonetwork/WEB-INF/config.xml
INFO [jeeves.engine] - Initializing general configuration...
INFO [jeeves.engine] - Initializing defaults...
INFO [jeeves.engine] - Default local is :true
INFO [jeeves.engine] - Initializing resources...
INFO [jeeves.engine] - Adding resource : main-db
INFO [jeeves.engine] - Loading activator :
org.fao.geonet.activators.McKoiActivator
INFO [jeeves.engine] - Starting activator :
INFO [jeeves.engine] - Initializing services...
INFO [jeeves.engine] - Adding service : main.home
INFO [jeeves.engine] - Adding service : main.search
INFO [jeeves.engine] - Adding service : main.search.embedded
INFO [jeeves.engine] - Adding service : main.present.embedded
main.searchform.advanced.embedded
INFO [jeeves.engine] - Adding service : main.searchform.simple.embedded
INFO [jeeves.engine] - Adding service : rating.popup
INFO [jeeves.engine] - Adding service : remote.show
INFO [jeeves.engine] - Adding service : feedback
INFO [jeeves.engine] - Adding service : links
INFO [jeeves.engine] - Adding service : about
INFO [jeeves.engine] - Adding service : xml.region.get
INFO [jeeves.engine] - Adding service : selection.search
INFO [jeeves.engine] - Adding service : feedback.insert
INFO [jeeves.engine] - Adding service : util.ping
INFO [jeeves.engine] - Adding service : util.import
INFO [jeeves.engine] - Adding service : user.list
INFO [jeeves.engine] - Adding service : user.get
INFO [jeeves.engine] - Adding service : user.edit
INFO [jeeves.engine] - Adding service : user.resetpw
INFO [jeeves.engine] - Adding service : user.update
INFO [jeeves.engine] - Adding service : user.remove
INFO [jeeves.engine] - Adding service : user.pwedit
INFO [jeeves.engine] - Adding service : user.pwupdate
INFO [jeeves.engine] - Adding service : user.infoedit
INFO [jeeves.engine] - Adding service : user.infoupdate
INFO [jeeves.engine] - Adding service : user.register.get
INFO [jeeves.engine] - Adding service : user.register.submit
INFO [jeeves.engine] - Adding service : group.list
INFO [jeeves.engine] - Adding service : group.get
INFO [jeeves.engine] - Adding service : group.update
INFO [jeeves.engine] - Adding service : group.remove
INFO [jeeves.engine] - Adding service : xml.group.update
INFO [jeeves.engine] - Adding service : category.list
INFO [jeeves.engine] - Adding service : category.get
INFO [jeeves.engine] - Adding service : category.update
INFO [jeeves.engine] - Adding service : category.remove
INFO [jeeves.engine] - Adding service : xml.category.update
INFO [jeeves.engine] - Adding service : user.login
INFO [jeeves.engine] - Adding service : shib.user.login
INFO [jeeves.engine] - Adding service : user.logout
INFO [jeeves.engine] - Adding service : admin
INFO [jeeves.engine] - Adding service : config
INFO [jeeves.engine] - Adding service : xml.config.get
INFO [jeeves.engine] - Adding service : xml.config.set
INFO [jeeves.engine] - Adding service : localization
INFO [jeeves.engine] - Adding service : xml.operation.update
INFO [jeeves.engine] - Adding service : xml.region.update
INFO [jeeves.engine] - Adding service : help
INFO [jeeves.engine] - Adding service : xml.schema.info
INFO [jeeves.engine] - Adding service : file.disclaimer
INFO [jeeves.engine] - Adding service : file.download
INFO [jeeves.engine] - Adding service : prepare.file.download
INFO [jeeves.engine] - Adding service : graphover.show
INFO [jeeves.engine] - Adding service : resources.get.archive
INFO [jeeves.engine] - Adding service : resources.upload
INFO [jeeves.engine] - Adding service : resources.prepare.upload
INFO [jeeves.engine] - Adding service : resources.del
INFO [jeeves.engine] - Adding service : xml.user.login
INFO [jeeves.engine] - Adding service : xml.user.logout
INFO [jeeves.engine] - Adding service : xml.search
INFO [jeeves.engine] - Adding service : xml.metadata.get
INFO [jeeves.engine] - Adding service : xml.info
INFO [jeeves.engine] - Adding service : xml.forward
INFO [jeeves.engine] - Adding service : xml.user.list
INFO [jeeves.engine] - Adding service : xml.usergroups.list
INFO [jeeves.engine] - Adding service : xml.group.list
INFO [jeeves.engine] - Adding service : xml.metadata.insert
INFO [jeeves.engine] - Adding service : xml.metadata.delete
INFO [jeeves.engine] - Adding service : csw
INFO [jeeves.engine] - Adding service : oaipmh
INFO [jeeves.engine] - Adding service : rss.latest
INFO [jeeves.engine] - Adding service : rss.search
INFO [jeeves.engine] - Adding service : rss.present
INFO [jeeves.engine] - Adding service : google.kml
INFO [jeeves.engine] - Adding service : mef.import
INFO [jeeves.engine] - Adding service : mef.export
INFO [jeeves.engine] - Adding service : xml.relation.get
INFO [jeeves.engine] - Adding service : xml.relation.insert
INFO [jeeves.engine] - Adding service : xml.relation.delete
INFO [jeeves.engine] - Adding service : keywords.getselected
INFO [jeeves.engine] - Adding service : keywords.sort
INFO [jeeves.engine] - Adding service : keywords.select
INFO [jeeves.engine] - Adding service : keywords.search
INFO [jeeves.engine] - Adding service : xml.search.keywords
INFO [jeeves.engine] - Adding service : xml.search.keywordlink
INFO [jeeves.engine] - Adding service : keywords.editsearch
INFO [jeeves.engine] - Adding service : thesaurus.admin
INFO [jeeves.engine] - Adding service : thesaurus.upload
INFO [jeeves.engine] - Adding service : thesaurus.download
INFO [jeeves.engine] - Adding service : thesaurus.delete
INFO [jeeves.engine] - Adding service : thesaurus.view
INFO [jeeves.engine] - Adding service : thesaurus.add
INFO [jeeves.engine] - Adding service : thesaurus.edit
INFO [jeeves.engine] - Adding service : thesaurus.update
INFO [jeeves.engine] - Adding service : thesaurus.editelement
INFO [jeeves.engine] - Adding service : thesaurus.addelement
INFO [jeeves.engine] - Adding service : thesaurus.updateelement
INFO [jeeves.engine] - Adding service : thesaurus.deleteelement
INFO [jeeves.engine] - Initializing schedules...
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-metadata.xml
INFO [jeeves.engine] - Adding service : metadata.insert.paste
INFO [jeeves.engine] - Adding service : metadata.show
INFO [jeeves.engine] - Adding service : metadata.show.embedded
INFO [jeeves.engine] - Adding service : metadata.edit
INFO [jeeves.engine] - Adding service : metadata.elem.add
INFO [jeeves.engine] - Adding service : metadata.elem.delete
INFO [jeeves.engine] - Adding service : metadata.update
INFO [jeeves.engine] - Adding service : metadata.update.finish
INFO [jeeves.engine] - Adding service : metadata.update.forget
INFO [jeeves.engine] - Adding service : metadata.update.forgetandfinish
INFO [jeeves.engine] - Adding service : metadata.validate
INFO [jeeves.engine] - Adding service : metadata.elem.down
INFO [jeeves.engine] - Adding service : metadata.elem.up
INFO [jeeves.engine] - Adding service : metadata.attr.add
INFO [jeeves.engine] - Adding service : metadata.attr.delete
INFO [jeeves.engine] - Adding service : metadata.delete
metadata.recent.additions.embedded
INFO [jeeves.engine] - Adding service : metadata.massive.delete
INFO [jeeves.engine] - Adding service : metadata.massive.newowner
INFO [jeeves.engine] - Adding service : metadata.massive.newowner.form
INFO [jeeves.engine] - Adding service : metadata.massive.category.form
metadata.massive.update.categories
INFO [jeeves.engine] - Adding service : metadata.massive.admin.form
metadata.massive.update.privileges
INFO [jeeves.engine] - Adding service : metadata.massive.processing
INFO [jeeves.engine] - Adding service : metadata.select
INFO [jeeves.engine] - Adding service : metadata.create.form
INFO [jeeves.engine] - Adding service : metadata.duplicate.form
INFO [jeeves.engine] - Adding service : metadata.admin.index.rebuild
INFO [jeeves.engine] - Adding service : metadata.admin.form
INFO [jeeves.engine] - Adding service : metadata.category.form
INFO [jeeves.engine] - Adding service : metadata.xmlinsert.form
INFO [jeeves.engine] - Adding service : metadata.batchimport.form
INFO [jeeves.engine] - Adding service : metadata.searchunused.form
INFO [jeeves.engine] - Adding service : metadata.thumbnail.form
INFO [jeeves.engine] - Adding service : metadata.thumbnail.set
INFO [jeeves.engine] - Adding service : metadata.thumbnail.unset
INFO [jeeves.engine] - Adding service : transfer.ownership
INFO [jeeves.engine] - Adding service : xml.ownership.editors
INFO [jeeves.engine] - Adding service : xml.ownership.groups
INFO [jeeves.engine] - Adding service : xml.ownership.transfer
INFO [jeeves.engine] - Adding service : xml.metadata.rate
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-harvesting.xml
INFO [jeeves.engine] - Adding service : harvesting
INFO [jeeves.engine] - Adding service : xml.harvesting.get
INFO [jeeves.engine] - Adding service : xml.harvesting.add
INFO [jeeves.engine] - Adding service : xml.harvesting.update
INFO [jeeves.engine] - Adding service : xml.harvesting.remove
INFO [jeeves.engine] - Adding service : xml.harvesting.start
INFO [jeeves.engine] - Adding service : xml.harvesting.stop
INFO [jeeves.engine] - Adding service : xml.harvesting.run
INFO [jeeves.engine] - Adding service : xml.harvesting.info
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-portal.xml
INFO [jeeves.engine] - Adding service : portal.search
INFO [jeeves.engine] - Adding service : portal.opensearch
INFO [jeeves.engine] - Adding service : portal.search.keywords
INFO [jeeves.engine] - Adding service : portal.present
INFO [jeeves.engine] - Adding service : portal.search.present
INFO [jeeves.engine] - Adding service : portal.get
INFO [jeeves.engine] - Adding service : portal.full
INFO [jeeves.engine] - Adding service : portal.latest.updated
INFO [jeeves.engine] - Adding service : portal.featured
INFO [jeeves.engine] - Adding service : portal.categories
INFO [jeeves.engine] - Adding service : portal.sources
INFO [jeeves.engine] - Adding service : pdf.search
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-export.xml
INFO [jeeves.engine] - Adding service : dc.xml
INFO [jeeves.engine] - Adding service : fgdc.xml
INFO [jeeves.engine] - Adding service : iso19115to19139.xml
INFO [jeeves.engine] - Adding service : iso19139.xml
INFO [jeeves.engine] - Adding service : iso_arccatalog8.xml
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-test.xml
INFO [jeeves.engine] - Adding service : test.i18n
INFO [jeeves.engine] - Adding service : test.i18n.xml
INFO [jeeves.engine] - Adding service : test.csw
C:\Program\geonetwork\web\geonetwork/WEB-INF/config-csw.xml
INFO [jeeves.engine] - Initializing profiles...
INFO [jeeves.engine] - Found handler : org.fao.geonet.Geonetwork
INFO [jeeves.engine] - --- Starting handler
INFO [jeeves.apphand] - Initializing geonetwork...
INFO [jeeves.apphand] - - Setting manager...
INFO [jeeves.apphand] - - Thesaurus...
INFO [jeeves.apphand] - - Z39.50...
INFO [jeeves.apphand] - Enabled. Schema mappings is :
schema-mappings.xml
INFO [jeeves.apphand] - - Search...
INFO [jeeves.apphand] - - Access manager...
INFO [jeeves.apphand] - - Data manager...
INFO [jeeves.apphand] - Adding xml schema : csw-record
INFO [jeeves.apphand] - Adding xml schema : dublin-core
INFO [jeeves.apphand] - Adding xml schema : fgdc-std
INFO [jeeves.apphand] - Adding xml schema : iso19115
INFO [jeeves.apphand] - Adding xml schema : iso19139
INFO [jeeves.apphand] - - Harvest manager...
INFO [jeeves.apphand] - - Catalogue services for the web...
INFO [jeeves.apphand] - - Open Archive Initiative (OAI-PMH) server...
INFO [jeeves.apphand] - Site ID is : c13d9897-14ef-4cb3-94bc-e8fc3e957030
INFO [jeeves.engine] - --- Handler started
INFO [jeeves.engine] - Starting schedule manager...
INFO [jeeves.engine] - Memory used is : 11573 Kb
INFO [jeeves.engine] - Total memory is : 520256 Kb
INFO [jeeves.engine] - Startup time is : 19 (secs)
INFO [jeeves.engine] - === System working ===================
INFO [jeeves.request] -
INFO [jeeves.request] - HTML Request (from 127.0.0.1) :
DEBUG [jeeves.request] - Method : GET
DEBUG [jeeves.request] - Content type : null
DEBUG [jeeves.request] - Accept : image/gif, image/jpeg, image/pjpeg,
image/pjpeg,
application/vnd.ms-excel, application/vnd.ms-powerpoint,
application/msword, application/x-
shockwave-flash, */*
DEBUG [jeeves.request] - Session id is 1sdcwshny9l8o
DEBUG [jeeves.request] - Session created for client : 127.0.0.1
INFO [jeeves.service] - Dispatching : main.home
DEBUG [jeeves.service] - -> no input parameters
INFO [jeeves.service] - -> dispatching to output for : main.home
INFO [jeeves.service] - -> transforming with stylesheet :
C:\Program\geonetwork\web\geonetwork/xsl/main-page.xsl
INFO [jeeves.service] - -> end transformation for : main.home
INFO [jeeves.service] - -> output ended for : main.home
INFO [jeeves.service] - -> dispatch ended for : main.home
/geonetwork/srv/en/resources.get
DEBUG [jeeves.request] - Accept : */*
INFO [jeeves.service] - Dispatching : resources.get
DEBUG [jeeves.service] - -> parameters are : <request> <id>12</id>
<access>public</access>
<fname>phy_s.gif</fname></request>
INFO [jeeves.webapp.resources.get] - File is :
INFO [jeeves.service] - -> dispatching to output for : resources.get
INFO [jeeves.service] - -> output ended for : resources.get
INFO [jeeves.service] - -> dispatch ended for : resources.get
DEBUG [jeeves.request] - Method : POST
DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
image/pjpeg,
INFO [jeeves.service] - Dispatching : user.login
<username>admin</username>
<password>admin</password> </request>
INFO [jeeves.webapp.user.login] - User 'admin' logged in as 'Administrator'
INFO [jeeves.service] - -> dispatching to output for : user.login
INFO [jeeves.service] - -> forwarding to : main.home
DEBUG [jeeves.service] - -> parameters are : <request> <forward
service="user.login" /></request>
DEBUG [jeeves.service] - -> parameters are : <request> <id>11</id>
<fname>thumbnail_s.gif</fname></request>
C:\Program\geonetwork\web\geonetwork\..\..\data\00000-00099\11\public\thumbnail_s.gif
/geonetwork/srv/en/portal.opensearch
DEBUG [jeeves.request] - Session id is pdxue755l5im
INFO [jeeves.service] - Dispatching : portal.opensearch
INFO [jeeves.service] - -> dispatching to output for : portal.opensearch
C:\Program\geonetwork\web\geonetwork/xsl/opensearch.xsl
INFO [jeeves.service] - -> end transformation for : portal.opensearch
INFO [jeeves.service] - -> output ended for : portal.opensearch
INFO [jeeves.service] - -> dispatch ended for : portal.opensearch
View this message in context: http://n2.nabble.com/IE8-error-message-Env-is-undefined-tp3716612p3716612.html
