Hello
I have one simple question
(If a simple question exists)
What is the best way to add/move/copy records from one geonetwork to
another ?
I have GN 3.10.3.0 that has around 400 records and I want to *move* them to
a new(another) GN and then maybe to GN 4.0.5 if possible.
Thanks, H贸ddi
H贸lmgr铆mur Helgason (H贸ddi)
CAFF - Data Manager
hoddi@anonymised.com
+354 462 3357
Hi H贸ddi
See feedback inline.
Jose Garc铆a
On Fri, Jul 2, 2021 at 1:58 PM H贸lmgr铆mur Helgason via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Hello
another ?
a new(another) GN
You want to move to another server, but using the same version of
GeoNetwork? If so I would export the current database and load it in the
new database and do the same for the data directory.
I would try first a similar approach as previous, and let GN 4.0.5 do the
migration, unfortunately sometimes is not that straightforward, but I would
try it.
Sorry if an obvious comment, but any migration should be done in a copy of
the production database, not directly with the production database.
Thanks, H贸ddi
CAFF - Data Manager
+354 462 3357
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose Garc铆a
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Thanks Jose for this.
What if I have two instances of GeoNetwork and want to combine them!
I would like to export from GN1 and import to GN2. I'm using H2 btw.
H贸ddi
CAFF - Data Manager
+354 462 3357
On Fri, 2 Jul 2021 at 14:32, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi H贸ddi
Jose Garc铆a
Hello
another ?
to
a new(another) GN
try it.
Thanks, H贸ddi
CAFF - Data Manager
+354 462 3357
this email.*
Hi H贸ddi
For the case you describe, an option I see is to export from GN1 to MEF
format the metadata and import the file in GN2. If both systems have the
same users / groups, the metadata privileges should be preserved. I would
try it first in a test instance.
Also for a production system I would not recommend H2, I would suggest
Postgres for production.
Jose Garc铆a
On Mon, Jul 5, 2021 at 10:47 AM H贸lmgr铆mur Helgason <hoddi@anonymised.com4...> wrote:
H贸ddi
CAFF - Data Manager
+354 462 3357
Hi H贸ddi
Jose Garc铆a
Hello
another ?
to
a new(another) GN
try it.
of the production database, not directly with the production database.
Thanks, H贸ddi
CAFF - Data Manager
+354 462 3357
this email.*
this email.*
