Hello everybody,
I'm a beginner in GeoNetwork and I have some trouble to import a metadata.
I'm working with the version 2.7 of GeoNetwork.
When I try to import a metadata with a xml file I have this output:
IllegalStateException : Root element not set
With a copy/past:
ServiceNotAllowedEx : Service not allowed
With a mef file:
With a mef file on gast:
Missing XML document in metadata folder private/metadata in MEF file
my_mef_file_name
My xml file are valid with oxygen. Did someone have same trouble ?
Thanks in advance,
Stéphane
hi Stéphane,
any chance you could share the XML and MEF files you've used ?
thanks,
Heikki Doeleman
On Mon, Jul 18, 2011 at 11:17 AM, Stéphane Delarue <
stephane.delarue62@anonymised.com> wrote:
Hello everybody,
With a copy/past:
With a mef file:
my_mef_file_name
Thanks in advance,
Stéphane
AppSumo Presents a FREE Video for the SourceForge Community by Eric
Ries, the creator of the Lean Startup Methodology on "Lean Startup
Secrets Revealed." This video shows you how to validate your ideas,
optimize your ideas and identify your business strategy.
http://p.sf.net/sfu/appsumosfdev2dev
GeoNetwork-users mailing list
Hi heikki,
Yes I can share, it's a free xml file who can be download in web. I attach
it on my mail.
Stéphane
2011/7/18 heikki <tropicano@anonymised.com>
hi Stéphane,
thanks,
Heikki Doeleman
Hello everybody,
With a copy/past:
With a mef file:
my_mef_file_name
Thanks in advance,
Stéphane
(attachments)
metadata.xml (16.7 KB)
metadata.mef (3.82 KB)
hi Stéphane,
the problem is caused by namespace declarations; for your document to be
valid, you only need
xmlns:gco="http://www.isotc211.org/2005/gco"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
Removing the other namespace declarations makes GeoNetwork import your
document fine.
Of course this is a bug, as your original document is a valid ISO19139
document and should not cause any error when you import it; could you please
open a bug report on GeoNetwork's trac
http://trac.osgeo.org/geonetwork/newticket (you'll need an OSGeo userid,
which you can obtain here https://www2.osgeo.org/cgi-bin/ldap_create_user.py)
thank you and kind regards
Heikki Doeleman
2011/7/18 Stéphane Delarue <stephane.delarue62@anonymised.com>
Hi heikki,
it on my mail.
Stéphane
hi Stéphane,
thanks,
Heikki Doeleman
Hello everybody,
metadata.
With a copy/past:
With a mef file:
my_mef_file_name
Thanks in advance,
Stéphane
Hi heikki,
Thanks a lot it's working. I will open the bug report soon.
Stéphane
hi Stéphane,
document fine.
https://www2.osgeo.org/cgi-bin/ldap_create_user.py) ?
Heikki Doeleman
Hi heikki,
it on my mail.
Stéphane
hi Stéphane,
thanks,
Heikki Doeleman
Hello everybody,
metadata.
With a copy/past:
With a mef file:
my_mef_file_name
Thanks in advance,
Stéphane
