Hello list,
I have installed GN 2.1 with Jetty and PostgreSQL 8.1 on an Ubuntu Server. Everything is working fine.
I would like to have some sample data for a presentation. That's why I tried to install the sample data and metadata using GAST. But there is an error massage on installing the data: "You need to authenticate". What? Where?
0 [Thread-1] WARN cookie.CookieSpec - Invalid cookie state: domain not specified
267 [Thread-1] INFO httpclient.HttpMethodDirector - Authentication requested but doAuthentication is disabled
267 [Thread-1] WARN httpclient.HttpMethodBase - Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
*** Error is:
<error id="service-not-allowed">
<message>Service not allowed</message>
<class>ServiceNotAllowedEx</class>
<stack>
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="369" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="600" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="163" method="execute" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="98" method="doPost" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="616" method="service" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="689" method="service" />
<at class="org.mortbay.jetty.servlet.ServletHolder" file="ServletHolder.java" line="427" method="handle" />
<at class="org.mortbay.jetty.servlet.WebApplicationHandler" file="WebApplicationHandler.java" line="473" method="dispatch" />
<at class="org.mortbay.jetty.servlet.ServletHandler" file="ServletHandler.java" line="568" method="handle" />
<at class="org.mortbay.http.HttpContext" file="HttpContext.java" line="1565" method="handle" />
</stack>
<object>mef.import</object>
<request>
<language>en</language>
<service>mef.import</service>
</request>
</error>
java.lang.Exception: You need to authenticate
at org.fao.gast.lib.ServiceLib.checkError(ServiceLib.java:77)
at org.fao.gast.gui.panels.database.sample.Worker.send(Worker.java:147)
at org.fao.gast.gui.panels.database.sample.Worker.executeJob(Worker.java:110)
at org.fao.gast.gui.panels.database.sample.Worker.run(Worker.java:73)
at java.lang.Thread.run(Thread.java:619)
Best regards,
Christian
http://www.ufz.de
Hi Christian,
When you want to load sample data using GAST, GAST logs in on your geonetwork
and loads the data.
To allow GAST to login,it needs to fill in the username and password in your
geonetwork, this is the authentication. You can configure this in the
"Options" of the GAST tool.
As you use Jetty, you can choose 'embedded' server for server configuration.
Fill in your geonetwork username and password into the "account"
configuration. This will have been standardly set to admin-admin.
dien
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
Christian Gadge
Sent: Friday, October 19, 2007 11:02 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Import Sample Data
Hello list,
specified
recommended.
*** Error is:
<stack>
</stack>
<request>
</request>
</error>
at
at
Best regards,
Christian
http://www.ufz.de
GeoNetwork-users mailing list
DISCLAIMER
This e-mail and any attachments thereto may contain information which is confidential and/or protected by intellectual property rights and are intended for the sole use of the recipient(s)named above. Any use of the information contained herein (including, but not limited to, total or partial reproduction, communication or distribution in any form) by persons other than the designated recipient(s) is prohibited. If you have received this e-mail in error, please notify the sender either by telephone or by e-mail and delete the material from any computer.
This e-mail message has been scanned for Viruses and Content and cleared.
I've been having the same problem on GN 2.1 / Ubuntu Feisty / MySQL /
Tomcat. Have you been able to get around this?
Paul Grzeszczak
Christian Gadge <christian.gadge@anonymised.com>
Sent by: geonetwork-users-bounces@lists.sourceforge.net
2007-10-19 05:02 AM
To
cc
Subject
Hello list,
Where?
specified
recommended.
*** Error is:
<stack>
</stack>
<request>
</request>
</error>
at
at
at
Best regards,
Christian
http://www.ufz.de
I struggled with the same problem but with PostGreSQL instead of MySQL
and finally got it to work. You need to click on Options in the top left
corner of the GAST GUI and provide your Geonetwork admin authentication
there.
Gavin Fleming
pgrzeszc@anonymised.com
Sent: 30 October 2007 02:43 PM
To: Christian Gadge
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Import Sample Data
Paul Grzeszczak
2007-10-19 05:02 AM
To
cc
Subject
Hello list,
Server.
an
Where?
specified
response
recommended.
*** Error is:
<stack>
</stack>
<request>
</request>
</error>
at
at
0)
at
Best regards,
Christian
http://www.ufz.de
