No, the problem is not this one. Identifiers are differentiated well.
Maybe that it results from the structure of the matadata ?
Message du 08/03/07 16:30
De : "Lagarde Pierre"
A : geonetwork-users@lists.sourceforge.net
Copie à :
Objet : Re: [GeoNetwork-users] Import XML limitation
Do you check that the third file doesn't have the same identifier than the first or the second ?
Open the XML files and check the tag ...
Pierre.
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de Romain Marrast
Envoyé : jeudi 8 mars 2007 16:25
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] Import XML limitation
I have installed Geonetwork recently but I could import only 2 metadata in Geonetwork .
At the third, I have this error : "Immediate unique constraint violation (_ANONYMOUS_CONSTRAINT_8) Columns = ( uuid ) Table = ( APP.Metadata )"
What's the problem ?
Thanks
Romain M
Sorry for my english..
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's Techsay panel and you'll get the chance to share your opinions on IT & business topics through brief surveys-and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
GeoNetwork-users mailing list
Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient néanmoins de
vérifier l'absence de corruption à sa réception. The contents of this email and any attachments are
confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
Hi Romain,
It looks very much that there is a uuid duplication though. Are you sure there's no other metadata in your calatog that already uses this identifier?
You could try to remove the uuid (or FileID) from the metadata and try again.
Ciao,
Jeroen
Copie à :
Pierre.
Thanks
Romain M
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
content.
