[GeoNetwork-users] Import XML limitation
Thanks for your help. There is no metadata which use same ID in our catalog. So, I deleted all the fileID of my metadatas, and now it works perfectly. Thank you very much,
Romain M.
Message du 08/03/07 16:55
De : "Jeroen Ticheler"
A : romain.marrast@anonymised.com
Copie à : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] Import XML limitation
Hi Romain,
It looks very much that there is a uuid duplication though. Are you
sure there's no other metadata in your calatog that already uses this
identifier?
You could try to remove the uuid (or FileID) from the metadata and
try again.
Ciao,
Jeroen
On Mar 8, 2007, at 4:47 PM, Romain Marrast wrote:
> No, the problem is not this one. Identifiers are differentiated well.
> Maybe that it results from the structure of the matadata ?
>> Message du 08/03/07 16:30
>> De : "Lagarde Pierre"
>> A : geonetwork-users@lists.sourceforge.net
>> Copie à :
>> Hi,
>> Do you check that the third file doesn't have the same identifier
>> than the first or the second ?
>> Open the XML files and check the tag ...
>> Pierre.
>> -----Message d'origine-----
>> De : geonetwork-users-bounces@lists.sourceforge.net
>> [mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part
>> de Romain Marrast
>> Envoyé : jeudi 8 mars 2007 16:25
>> À : geonetwork-users@lists.sourceforge.net
>> Objet : [GeoNetwork-users] Import XML limitation
>> Hi all,
>> I have installed Geonetwork recently but I could import only 2
>> metadata in Geonetwork .
>> At the third, I have this error : "Immediate unique constraint
>> violation (_ANONYMOUS_CONSTRAINT_8) Columns = ( uuid ) Table =
>> ( APP.Metadata )"
>> What's the problem ?
>> Thanks
>> Romain M
>> Sorry for my english..
>> Take Surveys. Earn Cash. Influence the Future of IT Join
>> SourceForge.net's Techsay panel and you'll get the chance to share
>> your opinions on IT & business topics through brief surveys-and
>> earn cash http://www.techsay.com/default.php?
>> page=join.php&p=sourceforge&CID=DEVDEV
>> _______________________________________________
>> GeoNetwork-users mailing list
>> GeoNetwork-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>> GeoNetwork OpenSource is maintained at http://sourceforge.net/
>> projects/geonetwork
>> Le contenu de cet e-mail et de ses pièces jointes est destiné à
>> l'usage exclusif du
>> (des) destinataire(s) expressément désigné(s) comme tel(s). En cas
>> de réception de cet
>> e-mail par erreur, le signaler à son expéditeur et ne pas en
>> divulguer le contenu.
>> L'absence de virus a été vérifié à l'émission du message. Il
>> convient néanmoins de
>> vérifier l'absence de corruption à sa réception. The contents of
>> this email and any attachments are
>> confidential. They are intended for
>> the named recipient(s) only. If you have received this email in
>> error please notify the
>> system manager or the sender immediately and do not disclose the
>> contents to
>> anyone or make copies. eSafe scanned this email for viruses,
>> vandals and malicious
>> content.
>> Join SourceForge.net's Techsay panel and you'll get the chance to
>> share your
>> opinions on IT & business topics through brief surveys-and earn cash
>> projects/geonetwork
> share your
> projects/geonetwork
For example Jeroen & Romain, when you said in 2007 to delete all the fileID
(i.e. UUID) of your metadatas before importing some XML, did you mean you
deleted from XMLs the blocks like
  <gmd:fileIdentifier>
      <gco:CharacterString xmlns:srv="http://www.isotc211.org/2005/srv&quot;
xmlns:gmx="http://www.isotc211.org/2005/gmx&quot;&gt;dbf50d22\-5ce4\-415b\-ba26\-72fb6838c350&lt;/gco:CharacterString&gt;
  </gmd:fileIdentifier>
or just the string, or to remove the IDs from those in the GeoNetwork
already? The UUID isometimes changes, possibly if you e.g. update the author
name. In any case, in the current version there are three options what the
application should do when importing data with a UUID already used.
Shouldn't they take care of the conflicts?
Arto
View this message in context: http://n2.nabble.com/Import-XML-limitation-tp2013481p4824247.html
