[GeoNetwork-users] Inconsistency between file names using r.horizon
Hope someone can give me a hand...
I'm using the r.horizon plugin (GRASS 7.6.1) in QGIS 3.8.3, which should
produce an output raster file for every direction I've specified (from
azimuth angle 0=East to 180=West, for example). The problem is I don't get
all the outputs I should, only the ones for angles >100. Apparently the
software begins the calculations and creates all the files, naming the
outputs:
outputda04053511ae49fa9d98db11bc54f4ac_000
outputda04053511ae49fa9d98db11bc54f4ac_090
outputda04053511ae49fa9d98db11bc54f4ac_180
But later when the software is creating layers based on these files, it does
a search for:
outputda04053511ae49fa9d98db11bc54f4ac_90
How do I solve this inconsistency between the name the software gave the
files, and the name it uses to retrieve them and create the layers?
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
