[GeoNetwork-users] incorrect URL
I am having an issue loading intermap..
intermap is simply not functioning
this is the error. i think it is because it is being directed to the wrong
url
<error id="error">
<message/>
<class>NullPointerException</class>
<stack>
<at class="org.wfp.vam.intermap.kernel.map.MapMerger" file="MapMerger.java"
line="600" method="merge"/>
<at class="org.wfp.vam.intermap.services.map.Update" file="Update.java"
line="80" method="exec"/>
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java"
line="238" method="execService"/>
line="141" method="execServices"/>
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="377" method="dispatch"/>
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="621"
method="dispatch"/>
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute"/>
file="JeevesServlet.java" line="89" method="doGet"/>
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="617" method="service"/>
line="717" method="service"/>
</stack>
<request>
<language>en</language>
<service>main</service>
</request>
</error>
anyway..
So then using Geoserver I tried the "demo request"
and the url it uses is
http://mib-gemcsw.nrcan.gc.ca:80/geoserver/wms?request=getCapabilities
when it should really be
http://mib-gemcsw.nrcan.gc.ca:8080/geoserver/wms?request=getCapabilities
any idea how to change it?
View this message in context: http://n2.nabble.com/incorrect-URL-tp4504006p4504006.html
if you don´t solved it yet you can look at web.xml (I think) at geoserver (geonetwork) folder and change port number.
Hope it helped a little bit.
best regards
Sarah
Von: cstieber <cstieber@anonymised.com>
An: geonetwork-users@lists.sourceforge.net
Gesendet: Dienstag, den 2. Februar 2010, 23:02:29 Uhr
Betreff: [GeoNetwork-users] incorrect URL
url
<error id="error">
<message/>
<stack>
method="dispatch"/>
</stack>
<request>
</request>
</error>
anyway..
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-users mailing list
__________________________________________________
Do You Yahoo!?
Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails.
http://mail.yahoo.com
