[GeoNetwork-users] index-fields.xsl error
What maybe go wrong with the following errors? did not change anything on index-fields.xsl.
Error on line 675 column 4 of index-fields.xsl:
SXXP0003: Error reported by XML parser: The element type "xsl:for-each" must be terminated
by the matching end-tag "</xsl:for-each>".
2015-07-08 16:57:16,898 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
Marking the metadata as _indexingError=1 in index
2015-07-08 16:57:17,017 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
2015-07-08 16:57:17,182 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
2015-07-08 16:57:17,265 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
2015-07-08 16:57:17,361 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
2015-07-08 16:57:17,450 ERROR [geonetwork.index] - Indexing stylesheet contains errors : Failed to compile stylesheet. 1 error detected.
Jul 08, 2015 4:57:34 PM org.apache.catalina.startup.HostConfig deployDirectory
