Dear List,
I try to configure input fields for an attribute with a "+" button in edit mode, but I didn't get correct configuration. I tried to copy some code from the layout.xsl of ISO19139 schema and modify it - could you please help me to correct it?
The attribute is "xlink:title" (in element ows:Metadata). It looks like this in the XML:
<ows:Metadata xlink:title="keyword_1"/>
<ows:Metadata xlink:title="keyword_2"/>
<ows:Metadata xlink:title="keyword_3"/>
And I like to get an input field for each of the values (keyword1-3) and "+" button below (to add new keywords).
The modified template looks like this:
<xsl:template mode="mode-mcp" priority="200" match="//ows:Metadata">
<xsl:param name="schema" select="$schema" required="no"/>
<xsl:param name="labels" select="$labels" required="no"/>
<xsl:variable name="name" select="concat(@prefix, ':', @name)"/>
<xsl:variable name="flatModeException" select="gn-fn-metadata:getFieldFlatModeException($viewConfig, $name)"/>
<xsl:variable name="directive" select="'text'"/>
<xsl:call-template name="render-element-to-add">
<xsl:with-param name="label" select="/root/gui/schemas/mcp/strings/metadata"/>
<xsl:with-param name="directive" select="if($directive != 'text') then $directive else ''"/>
<xsl:with-param name="childEditInfo" select="@xlink:title"/>
<xsl:with-param name="parentEditInfo" select="../gn:element"/>
<xsl:with-param name="isFirst" select="count(preceding-sibling::*[name() = $name]) = 0"/>
</xsl:call-template>
</xsl:template>
What parameters should I modify and how? Or maybe there is a documentation of how to do this and I just could not find it on the Web?
Christin.
