Hello! I was wondering if there was any way to insert or import new meta data
into geonetwork without using the web interface or the gasp utility. I want
to add a metadata from an external application, is there any api for this?
or the only solution is to insert the data directly into the geonetwork
database? Thanks!
View this message in context: http://n2.nabble.com/Insert-new-metadata-from-external-application-tp3117954p3117954.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
