Hello everybody,
I'm starting to use geonetwork for my organization.
First of all I deployed the WAR version, and now it is running on my application server.
First question is on user interfaces personalization, I would like to change and try not only the classic gui but also the tabsearch and html5ui.
I read that is possible only compiling from source geonetwork, is that true? no way with war version?
Second point is on INSPIRE. How can I use the INSPIRE metadata schema? How can I import INSPIRE template metadata schema? Is it possible? If I would define a mine personal metadata schema, how can I set it up on geonetwork?
Thank you for your collaboration,
regards
Eugenio
