Hi
Enable INSPIRE support, I don't think is really used in the new Angular UI,
but not totally sure.
About the editor view, to enable it, you need to remove the disable="true"
in
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/layout/config-editor.xml#L276
Also you'll need to rename the schematron files related to INSPIRE
https://github.com/geonetwork/core-geonetwork/tree/develop/schemas/iso19139/src/main/plugin/iso19139/schematron
schematron-rules-inspire.disabled.sch --> schematron-rules-inspire.sch
Once these changes are done, a restart of GeoNetwork is required.
Jose García
On Fri, Oct 7, 2016 at 11:25 AM, Julian Hollingbery <julian@anonymised.com>
wrote:
I'm not exactly sure about the extent of "enable INSPIRE support", but I
do now this: If you want to upload the thesaurus via URL directly from
GitHub, you need to use the "raw" content, i.e.
https://raw.githubusercontent.com/geonetwork/util-gemet/
master/thesauri/inspire-theme.rdf
/julian
-----Oprindelig meddelelse-----
Fra: Andžej Miloš [mailto:Andzej.Milos@anonymised.com]
Sendt: 3. oktober 2016 14:44
Til: geonetwork-users@lists.sourceforge.net
Emne: [GeoNetwork-users] INSPIRE compatibility
Hello,
I have a general question:
what does it mean in GeoNetwork to enable INSPIRE support?
does it enables INSPIRE metadata editor which e.g. shows what fields are
required for metadata to be compatible with INSPIRE directive?
I also tried to upload INSPIRE themes thesaurus
https://github.com/geonetwork/util-gemet/blob/master/
thesauri/inspire-theme.rdf but it did not work: thesaurusUploadError.
It would be great if somebody could share their experience to make
GeoNetwork to support INSPIRE.
Thank you
Kind regards,
Andžej Miloš
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
