Hi Jose,
thank you for your response. I had already seen the xslt ArcCatalog8_to_ISO19115 but it didn't work with my xml file (attached) so I thought it maybe was specific to ArcCatalog 8 and not ArcCatalog 10.3. When I try to import the xml file (with Geonetwork web interface), I have this error :
Import report
Autodetecting schema failed for metadata record with root element
Metadata in namespace [Namespace: prefix "" is mapped to URI ""].
Indeed, I don't have any namespace. Is it really a problem ?
Thank you in advance for any idea,
/Sophie MOLLARD/
/Pôle Géomatique/
/MSHE C. N. Ledoux (USR 3124) <http://mshe.univ-fcomte.fr>/
/Université de Franche-Comté/
/Tél : 03.81.66.51.55/
Le 13/05/2016 17:04, Jose Garcia a écrit :
Hi Sophie
The metadata import allows to specify a xslt to translate the metadata and there're some xslt processes defined for this. Indeed one of them is for what you want.
The doc is for GeoNetwork 2.10, but should be similar in GeoNetwork 3, see the *styleSheet *parameter:
http://geonetwork-opensource.org/manuals/2.10.4/eng/developer/xml_services/metadata_xml_insert_update_delete.html#insert-metadata-xml-metadata-insert
Check to send ArcCatalog8_to_ISO19115.xsl orArcCatalog8_to_ISO19115 (not sure if the file extension is required). That stylesheet should convert from ArcGIS xml to iso19139 format.
Jose García
On Fri, May 13, 2016 at 4:58 PM, Sophie Mollard <sophie.mollard@anonymised.com <mailto:sophie.mollard@anonymised.com>> wrote:
Hi list,
I would like to translate ArcGIS XML metadata into Inspire ISO19139
format using command lines. I can't use arcpy translator because the
metadata with which I'm working aren't mine. Then, I push metadata on
GeoNetwork using OWSlib.
I'm trying to work with SaxonB but I don't find any xsl file. Maybe I
could create it but I would like to be sure that it doesn't exist
somewhere.
Have you any idea or another idea ?
Thank you in advance,
/Sophie MOLLARD/
/Pôle Géomatique/
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition
of MDM
restrictions. Mobile Device Manager Plus allows you to control
only the
apps on BYO-devices by containerizing them, leaving personal data
untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
GeoNetwork-users mailing list
<mailto:GeoNetwork-users@lists.sourceforge.net>
Vriendelijke groeten / Kind regards,
Jose García
<http://www.geocat.net/>
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664 <tel:+31318416664>
<https://www.facebook.com/geocatbv><https://twitter.com/geocat_bv><https://plus.google.com/u/1/+GeocatNetbv/posts>
Please consider the environment before printing this email.
(attachments)
Haies_Franche_Comte.shp.xml (20.5 KB)
