I recently installed the latest version of GN (2.6.4) and created a sample metadataset. I couldn't find a solution to validate it according to inspire rules (like I saw in some screenshots). Is there an easy way to add an inspire-schema so that it tells me in the report: [INSPIRE: Table... - Row...]? I thought this would be implemented in this version whereas I also read that this doesn't come by default. I tried to look it up but I could only find:
"2.6.x series : manually copy INSPIRE Schematron from source or to run 'ant inspire' in the Schematrons directory."
Question: Where can I find this INSPIRE Schematron? And where should it be copied?
If I upload a xml file created in GN and try to validate it in another INSPIRE-conform editor, it shows several errors. Are the (INSPIRE-)Editors that different in their requirements?
It's the first time I'm working with GN so please excuse my cluelessness. Cheers,
Michael
