I'm having a problem with INSPIRE search in GN 2.8. I'm not sure if there
is a problem with my configuration or there is some bug in GN. I put a
keyword from INSPIRE Themes thesaurus into my metadata and when I select
this keyword in metadata search filter I don't get any results (all INSPIRE
options in administration panel are checked). I tried the same search with
the same metadata in GN 2.6.4 and there is everything ok. I also tried to
rebuild Lucene index but I receive the exception shown below.
Any help is appreciated.
Marko
Exception stacktrace:
2013-03-27 17:14:32,290 ERROR [geonetwork.index] - Rebuilding lucene index
2013-03-27 17:14:32,290 ERROR [geonetwork.lucene] - Failure while closing
luceneIndexLanguageTracker
org.apache.lucene.store.AlreadyClosedException: this Directory is closed
at org.apache.lucene.store.Directory.ensureOpen(Directory.java:290)
at org.apache.lucene.store.RAMDirectory.listAll(RAMDirectory.java:116)
at
org.apache.lucene.store.NRTCachingDirectory.close(NRTCachingDirectory.java:288)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.close(LuceneIndexLanguageTracker.java:197)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.reset(LuceneIndexLanguageTracker.java:167)
at
org.fao.geonet.kernel.search.SearchManager.setupIndex(SearchManager.java:1256)
at
org.fao.geonet.kernel.search.SearchManager.rebuildIndex(SearchManager.java:1283)
at
org.fao.geonet.services.metadata.IndexRebuild.exec(IndexRebuild.java:73)
at
jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:230)
at
jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:139)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:420)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:747)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:208)
at
jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:109)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at
at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at
org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at
at
at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:662)
2013-03-27 17:14:32,291 ERROR [geonetwork.lucene] - Failure while closing
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
