[GeoNetwork-users] INSPIRE Strict rules error
I'm using the last version of GN available here: https://github.com/titellus/core-geonetwork (3.7)
I tried to insert validate a metadata (ISO19139) that was fully validated in the other version of GN I'm using (GN 3.4.4) but I got these errors:
Invalid Conformity Title: ''Expected Conformity Title: 'commission regulation (eu) no 1089/2010 of 23 november 2010 implementing directive 2007/2/ec of the european parliament and of the council as regards interoperability of spatial data sets and services'
Conformance report requires a title in the metadata language
These errors are repeated 18 times.
Does anybody face the same error? Is there the possibility to solve this error as it was in the 3.4.4?
Thanks
Bart
Bartolomeo Ventura, PhD
Eurac Research
Institute for Earth Observation
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/&gt;
Le mar. 30 avr. 2019 à 12:17, Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> a écrit :
I think in 3.4.x the schematron for INSPIRE strict rules was disabled by
default unless you changed it. So I suggest to turn it off from admin >
metadata and template > validation and ignore this level of validation if
you don't need it.
Cheers.
Francois
Thanks
Bart
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
GeoNetwork-users mailing list
