[GeoNetwork-users] inspire template and other things
Dear Geonework Users,
I have just installed the war file of geonework under tomcat6 on a
Ubuntu 10.4 server.
All is working quite well.
I have some questions:
(1) I can't find an INSPIRE template for metadata. My question is:
if I create a metadata using this portal:
http://www.inspire-geoportal.eu/index.cfm/pageid/342
and then I save the xml and I import it as a template into geonetwork,
is it correct to say that I have created an INSPIRE template for
geonetwork?
(2) I see that the map (visualizer) is empty at start. I would like to
add a base map as the blue marble or something else. I have tried using
the "add layer" button but, it seems the layer is not loaded on the map
and, moreover, it is added to the "overlay" node of the layers tree not
to the "base" node.
how to add a base layer to the map? should I define this layers in the
openlayer file? where I can find it?
many many thanks
Ivan
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@anonymised.com
        ivan.marchesini@anonymised.com
fax (home): +39(0)5782830887
jabber: geoivan73@anonymised.com
skype: geoivan73
Hi Ivan
About (1), I think is ok the way you comment to create the INSPIRE template.
About (2), geonetwork.war uses a GeoServer configured with the default
layers of GeoNetwork. But this customized GeoServer is not delivered as a
war file as GeoNetwork. You can try one of these things:
* Install GeoNetwork with installer to a temporal folder and get the
geoserver.war from INSTALL_FOLDER/web/geoserver.war to deploy in your
tomcat, or
* configure in GeoNetwork the file WEB-INF/config-gui.xml with the layers
from external WMS servers to show in map search/viewer. For example:
<mapSearch options="{projection: 'EPSG:4326', maxExtent: new
OpenLayers.Bounds(-180,-90,180,90), units: 'm', restrictedExtent: new
OpenLayers.Bounds(-180,-90,180,90)}">
  <layers>
    <layer server="http://www2.demis.nl/wms/wms.ashx?WMS=BlueMarble&quot;
tocName="Map" params="{layers: 'Earth Image,Borders,Coastlines', format:
'image/jpeg'}" options="{isBaseLayer: true}" />
  </layers>
</mapSearch>
<mapViewer options="{projection: 'EPSG:4326', maxExtent: new
  <layers>
tocName="Borders" params="{layers: 'Borders,Coastlines', transparent:
'true', format: 'image/png'}" options="{}" />
tocName="Ortophoto" params="{layers: 'Earth Image', format: 'image/png'}"
  </layers>
</mapViewer>
Jose García
GeoCat bv
http://geocat.net
2011/1/16 ivan marchesini <ivan.marchesini@anonymised.com>
Ubuntu 10.4 server.
geonetwork?
to the "base" node.
many many thanks
Ivan
Ivan Marchesini
Perugia (Italy)
http://www.gfoss.it
skype: geoivan73
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
Hi Ivan,
2011/1/16 ivan marchesini <ivan.marchesini@anonymised.com>:
Ubuntu 10.4 server.
geonetwork?
"Image2000 Product 1 (nl2) Multispectral" provided in A.12.1.2 of the
Metadata IR [1] could be a good start I think.
Cheers.
Francois
[1] http://inspire.jrc.ec.europa.eu/index.cfm/pageid/101
to the "base" node.
many many thanks
Ivan
Ivan Marchesini
Perugia (Italy)
skype: geoivan73
Hi Ivan,
About your cuestion number one, i think you are in the right way. The manual describe the process of creating a template as you say.
We also make a template for a SDI as you explain.
Miguel Ángel.
-----Mensaje original-----
De: jose garcia [mailto:josegar74@anonymised.com]
Enviado el: lunes, 17 de enero de 2011 8:54
Para: ivan.marchesini@anonymised.com
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] inspire template and other things
Hi Ivan
tomcat, or
  <layers>
  </layers>
</mapSearch>
  <layers>
  </layers>
</mapViewer>
Jose García
GeoCat bv
http://geocat.net
Ubuntu 10.4 server.
geonetwork?
to the "base" node.
many many thanks
Ivan
Ivan Marchesini
Perugia (Italy)
http://www.gfoss.it
skype: geoivan73
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
Many thanks Jose..
Ivan
Il giorno lun, 17/01/2011 alle 08.54 +0100, jose garcia ha scritto:
Hi Ivan
template.
as a war file as GeoNetwork. You can try one of these things:
tomcat, or
layers from external WMS servers to show in map search/viewer. For
example:
  <layers>
format: 'image/jpeg'}" options="{isBaseLayer: true}" />
  </layers>
</mapSearch>
  <layers>
'image/png'}" options="{isBaseLayer: true}" />
  </layers>
</mapViewer>
Jose García
GeoCat bv
http://geocat.net
        on a
        Ubuntu 10.4 server.
        is:
        geonetwork,
        for
        geonetwork?
        like to
        tried using
        on the map
        tree not
        to the "base" node.
        layers in the
        many many thanks
        Ivan
        Ivan Marchesini
        Perugia (Italy)
        skype: geoivan73
        Understand
        and how you
Ivan Marchesini
Perugia (Italy)
skype: geoivan73
Hi Miguel,
thnaks for your answer..
ivan
Il giorno mer, 19/01/2011 alle 09.27 +0100, Miguel Ángel Parrilla
Godínez ha scritto:
Hi Ivan,
Miguel Ángel.
Hi Ivan
tomcat, or
  <layers>
  </layers>
</mapSearch>
  <layers>
  </layers>
</mapViewer>
Jose García
GeoCat bv
http://geocat.net
> Ubuntu 10.4 server.
> geonetwork?
> to the "base" node.
> many many thanks
> Ivan
> Ivan Marchesini
> Perugia (Italy)
> http://www.gfoss.it
> skype: geoivan73
Ivan Marchesini
Perugia (Italy)
skype: geoivan73
