Hi there,
I have installed geonetworks version 2.10 and on start up I get the following exception
(C) Exc : java.lang.IllegalArgumentException: The thesaurus external.theme.inspire-theme does not exist, there for the query cannot be excuted: 'Query [query=SELECT DISTINCT id,uppc,lowc,broader,eng_prefLabel,eng_note FROM {id} rdf:type {skos:Concept},[{id} gml:BoundedBy {} gml:upperCorner {uppc}],[{id} gml:BoundedBy {} gml:lowerCorner {lowc}],[{id} skos:broader {broader}],[{id} skos:prefLabel {eng_prefLabel} WHERE lang(eng_prefLabel) LIKE "en" IGNORE CASE],[{id} skos:scopeNote {eng_note} WHERE lang(eng_note) LIKE "en" IGNORE CASE] WHERE (eng_prefLabel LIKE "***" IGNORE CASE OR id LIKE "*") LIMIT 35 USING NAMESPACE skos=<http://www.w3.org/2004/02/skos/core#>,gml=<http://www.opengis.net/gml#>, interpreter=KeywordResultInterpreter]'
I tried going to administration > Manage thesauri > Add > From remote file > from thesaurus repository but the drop down is empty.
How do I solve this error?
Cheers.
Kind Regards,
Petula Lau
Software Developer
NIWA
Please consider the environment before printing this email.
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
2013/8/12 Petula Lau <Petula.Lau@anonymised.com>
Hi there,
following exception
You could try downloading the thesaurus from here
https://github.com/geonetwork/util-gemet/tree/master/thesauri and upload it
to your catalog.
By the way, it should not be needed as far as you turn off INSPIRE in admin
system configuration.
HTH.
Francois
Cheers.
Kind Regards,
Petula Lau
Software Developer
NIWA
Research Ltd.
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
