Hi Byron,
Sorry for my slow response, I've been in meetings this week.
Anyway, the startup procedure you describe is exactly what I've done,
including the last line in the start server window.
I went to the jetty/logsgeonetwork.log and nothing jumped out to me as
failing.
Here are the things I've tried:
Original install was from the exe. So I uninstalled, rebooted, and
installed from JAR.
I'm installing in c:\geonetwork to avoid any premission issues with
program files.
I set the permission on the c:\geonetwork\ to give "everyone" full access
(in case it was a permission problem).
And finally, I edited the necessary files to try a different port (8088
instead of 8080).
I'm just interested in using the software myself at this point and not
serving it to anyone else. More working with importing metadata etc.
As I said in my original post (or at least I meant to). version 2.2
installed flawlessly. However, I'm very interested in being able to do
temporal searches and my understanding is that should be implemented in
2.6.
thank you for your help!
VeeAnn
ByronCinNZ <cochranes4@anonymised.com> wrote on 09/21/2011 07:41:07 PM:
[image removed]
Re: [GeoNetwork-users] install problem 2.6.4
ByronCinNZ
to:
geonetwork-users
09/21/2011 07:45 PM
Hello VeeAnn,
XP installs are usually pretty straight forward, but various issues can
arise. Perhaps you can tell me a bit more. First, let's verify your
start up
proceedure. After installing the software you:
1. Go to the Start Menu and click GeoNetwork -> Start server. The icon
on
the tray can be clicked to open a DOS command window. It is good to
watch
this window when you start GeoNetwork to catch startup errors.
2. After waiting a few moments, you go to the Start Menu and click
GeoNetwork -> Open GeoNetwork opensource. It is important to wait a few
moments to give the indexing and jetty time to finish launching.
I have had occasions where some hard to find hidden conflict prevents
Jetty
from starting - usually a java issue. Watch the DOS window feedback on
startup for any clues. Post anything that looks unusual and we can go
from
there. There should be something showing if the program is giving a 404
error. The last line before you try to access GeoNetwork through your
browser should say something like "Started
SelectChannelConnector@anonymised.com:8080".
Byron Cochrane
LISAsoft
View this message in context: http://osgeo-org.
1803224.n2.nabble.com/install-problem-2-6-4-tp6816515p6818331.html
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2dcopy1
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
