[GeoNetwork-users] Installation Failure
I have just downloaded version 3.0 of GeoNetwork but getting lots of issues
when trying to install.
To start with I am running Windows 7 (64 bit)
I used the normal double click method to open the .jar file and followed
the bouncing ball. The install finished and I press Next and it just stalls
at that point with the cursor circle going around and around. After waiting
a while I had to close the window but nothing installed.
I then tried running it at the command line and got the following output
and failure at the same point.
C:\Users\deanhowell\Downloads>java -jar geonetwork-install-3.0.0-0.jar
could not create shortcut instance
java.lang.Exception: unidentified problem initializing COM
java.lang.UnsatisfiedLinkError:
com.izforge.izpack.util.os.ShellLink.initializeC
OM()I
        at com.izforge.izpack.util.os.ShellLink.initialize(Unknown Source)
        at com.izforge.izpack.util.os.ShellLink.<init>(Unknown Source)
        at com.izforge.izpack.util.os.Win_Shortcut.initialize(Unknown
Source)
        at com.izforge.izpack.panels.ShortcutPanel.panelActivate(Unknown
Source)
        at com.izforge.izpack.installer.InstallerFrame.switchPanel(Unknown
Sourc
e)
        at com.izforge.izpack.installer.InstallerFrame.navigateNext(Unknown
Sour
ce)
Sour
ce)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler.navigat
e(Unknown Source)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler.access$
100(Unknown Source)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler$1.run(U
nknown Source)
        at java.lang.Thread.run(Unknown Source)
java.lang.NullPointerException
        at
com.izforge.izpack.util.os.Win_Shortcut.getProgramsFolder(Unknown Sou
rce)
        at
com.izforge.izpack.panels.ShortcutPanel.getProgramsFolder(Unknown Sou
rce)
Source)
Sourc
e)
Sour
ce)
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Exception in thread "Thread-13" java.lang.NullPointerException
        at com.izforge.izpack.panels.ShortcutPanel.isValidated(Unknown
Source)
        at com.izforge.izpack.installer.IzPanel.panelValidated(Unknown
Source)
Sour
ce)
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Any thoughts?
are you running as administrator role?
On Thu, May 7, 2015 at 10:34 PM, Dean Howell <deanhowell2009@anonymised.com>
OM()I
Source)
Source)
Sourc
e)
Sour
ce)
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
        at
rce)
        at
rce)
Source)
Sourc
e)
Sour
ce)
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Source)
Source)
Sour
ce)
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Any thoughts?
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
David Percy ("Percy")
-Geospatial Data Manager
-Web Map Wrangler
-GIS Instructor
Portland State University
-gisgeek.pdx.edu
-geology.pdx.edu
No
issues
stalls
waiting
OM()I
Source)
Source)
Sourc
e)
        at
Sour
ce)
        at
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
        at
rce)
        at
rce)
Source)
Sourc
e)
        at
Sour
ce)
        at
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Source)
Source)
        at
Sour
ce)
        at
Sour
ce)
        at
e(Unknown Source)
        at
100(Unknown Source)
        at
nknown Source)
Any thoughts?
-Web Map Wrangler
-GIS Instructor
-gisgeek.pdx.edu
-geology.pdx.edu
Hi
There was a similar issue reported for Windows Server 64bit, probably the
same you have with Windows 7 64bit. I put here the solution that was
pointed by Francois:
*See https://github.com/geonetwork/core-geonetwork/issues/983
<https://github.com/geonetwork/core-geonetwork/issues/983&gt;\*
*As a workaround, you could *
** use the WAR file to install the application*
** or copy the installation from the working machine*
Jose GarcĂ­a
On Fri, May 8, 2015 at 8:03 AM, Dean Howell <deanhowell2009@anonymised.com>
wrote:
No
>> issues
>> stalls
>> waiting
>> OM()I
Source)
>> Source)
>> Source)
>> at
>> Sourc
>> e)
>> at
>> Sour
>> ce)
>> at
>> Sour
>> ce)
>> at
>> e(Unknown Source)
>> at
>> 100(Unknown Source)
>> at
>> nknown Source)
>> at
>> rce)
>> at
>> rce)
>> Source)
>> at
>> Sourc
>> e)
>> at
>> Sour
>> ce)
>> at
>> Sour
>> ce)
>> at
>> e(Unknown Source)
>> at
>> 100(Unknown Source)
>> at
>> nknown Source)
>> Source)
>> Source)
>> at
>> Sour
>> ce)
>> at
>> Sour
>> ce)
>> at
>> e(Unknown Source)
>> at
>> 100(Unknown Source)
>> at
>> nknown Source)
>> Any thoughts?
>> _______________________________________________
> -Web Map Wrangler
> -GIS Instructor
> -gisgeek.pdx.edu
> -geology.pdx.edu
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for
details. _________________________Jose GarcĂ­aGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
