[GeoNetwork-users] Installation from trunk
Hi all!
Im trying to install the latest version from trunk to get the profile plugin
support.
I checked out from
"https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk"\.
Then cant find out how to install.. Should I be looking for a jar-file, or
do I need to compile and run something from cmd?
Also, do you know when to expect a stable release with profile plugin
support?
Thank you for your patience with a beginner :slight_smile:
/ hbg
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installation-from-trunk-tp4361402p4361402.html
hi,
yes, if you check out the sources you have to build it.
In the GN root directory type "mvn install". This will produce a WAR file
you could deploy into e.g. Tomcat. If you want an executable installer that
uses an embedded Jetty servlet container, *after* doing mvn install, go to
the directory 'installer' and type ant.
Hope this helps,
kind regards
Heikki Doeleman
On Fri, Feb 3, 2012 at 11:54 AM, hbg <anders.jurisoo@anonymised.com> wrote:
Hi all!
plugin
support.
I checked out from
"https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk&quot;\.
support?
/ hbg
Try before you buy = See our experts in action!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-dev2
GeoNetwork-users mailing list
Hi Heikki,
and thanks alot for helping me out.
I still fail the build though, error at "GeoNetwork WebModule"- see below.
I have installed Maven, switched from Java JRE to JDK and did setup
enviroment variables (path)..
Running it on Microsoft Windows Server 2003 Standard x64 Edition.
Any ideas what im doing wrong?
best regards
/hbg
INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource ............................. SUCCESS [0.547s]
[INFO] Caching xslt module ............................... SUCCESS [1.781s]
[INFO] Jeeves modules .................................... SUCCESS [2.313s]
[INFO] Oaipmh modules .................................... SUCCESS [0.922s]
[INFO] ArcSDE module (dummy-api) ......................... SUCCESS [0.891s]
[INFO] GeoNetwork web client module ...................... SUCCESS [56.695s]
[INFO] GeoNetwork Web module ............................. FAILURE [13.471s]
[INFO] GeoServer module .................................. SKIPPED
[INFO] Gast module ....................................... SKIPPED
[INFO] GeoNetwork Integration Tests ...................... SKIPPED
[INFO]
[INFO] BUILD FAILURE
[INFO]
[INFO] Total time: 1:17.105s
[INFO] Finished at: Fri Feb 03 16:20:30 CET 2012
[INFO] Final Memory: 33M/96M
[INFO]
[ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.1:exec
(ant-schematrons) on project geonetwork-main: Result of cmd.exe /X /C "ant"
execution is: '1'. -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute
goal org.codehaus.mojo:exec-maven-plugin:1.1:exec (ant-schematrons) on
project geonetwork-main: Result of cmd.exe /X /C "ant" execution is: '1'.
  at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:217)
  at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at
org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
  at
org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
  at
org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
  at
org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
  at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
  at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
  at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.lang.reflect.Method.invoke(Method.java:601)
  at
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
  at
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
  at
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
  at
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: org.apache.maven.plugin.MojoExecutionException: Result of cmd.exe
  at org.codehaus.mojo.exec.ExecMojo.execute(ExecMojo.java:260)
  at
org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
  at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
  ... 19 more
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installation-from-trunk-tp4361402p4362155.html
hmm no I've no immediate idea what goes wrong. If you are using Maven 3,
maybe try it with Maven 2 ? (I use Maven 2.2.1)
On Fri, Feb 3, 2012 at 4:31 PM, hbg <anders.jurisoo@anonymised.com> wrote:
Hi Heikki,
best regards
/hbg
INFO]
[INFO]
[56.695s]
[13.471s]
[INFO]
[INFO]
[INFO]
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
cmd.exe
       at
       at
       ... 19 more
or, maybe it's because you do not have Ant ? You need it too ..
Hi Heikki,
best regards
/hbg
INFO]
[INFO]
[0.547s]
[1.781s]
[2.313s]
[0.922s]
[0.891s]
[56.695s]
[13.471s]
[INFO]
[INFO]
[INFO]
"ant"
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
cmd.exe
       at
       at
       ... 19 more
Yes, fixed Ant and it built fine! And Ill go with the embedded Jetty. Failed
building with "ant" in installer dir now though but hopefully its no big
deal? Ill be back on monday to try and fix it. If you want to look on it its
attached below..
Again, thanks!
/hbg
C:\TEMP\geonetwork\installer>ant
Buildfile: C:\TEMP\geonetwork\installer\build.xml
setProperties:
    [mkdir] Created dir: C:\TEMP\geonetwork\.props
BUILD FAILED
C:\TEMP\geonetwork\installer\build.xml:91: Execute failed: java.io.IOExce
ption: Cannot run program "svn": CreateProcess error=2, The system cannot
find t
he file specified
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installation-from-trunk-tp4361402p4362435.html
Hi
You need also Subversion command line tools installed. The installer
creates a file server.prop with the SVN information of the revision used
for the installer.
Check in
http://geonetwork-opensource.org/manuals/trunk/eng/developer/development/index.html#tools
all
the tools required to setup the development environment.
Sphinx is not required unless you build the documentation, this is disabled
by default.
Jose García
Failed
its
attached below..
Again, thanks!
/hbg
setProperties:
BUILD FAILED
find t
he file specified
Thanks all you guys, now im up and running!
It was the SVN client I used, Tortoise the default version didtn support the
svn command in cmd. Changed to SlikSVN instead..
Jose, thats a great page! I missed it, that was basically what i was looking
for all the time.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installation-from-trunk-tp4361402p4368679.html
