[GeoNetwork-users] Installation issue
Good morning.
I have downloaded "geonetwork-install-3.2.1-0.jar" to install GeoNetwork in a Windows 10 computer with Java 8. When I click next after the installation, the following error appears:
java.lang.Exception: error loading library
java.lang.Exception: can't locate library
        at com.izforge.izpack.util.Librarian.loadArchSpecificLibrary(Unknown Source)
        at com.izforge.izpack.util.Librarian.loadLibrary(Unknown Source)
        at com.izforge.izpack.util.os.ShellLink.initialize(Unknown Source)
        at com.izforge.izpack.util.os.ShellLink.<init>(Unknown Source)
        at com.izforge.izpack.util.os.Win_Shortcut.initialize(Unknown Source)
        at com.izforge.izpack.panels.ShortcutPanel.panelActivate(Unknown Source)
        at com.izforge.izpack.installer.InstallerFrame.switchPanel(Unknown Source)
        at com.izforge.izpack.installer.InstallerFrame.navigateNext(Unknown Source)
        at com.izforge.izpack.installer.InstallerFrame$NavigationHandler.navigate(Unknown Source)
        at com.izforge.izpack.installer.InstallerFrame$NavigationHandler.access$100(Unknown Source)
        at com.izforge.izpack.installer.InstallerFrame$NavigationHandler$1.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
java.lang.NullPointerException
        at com.izforge.izpack.util.os.Win_Shortcut.getProgramsFolder(Unknown Source)
        at com.izforge.izpack.panels.ShortcutPanel.getProgramsFolder(Unknown Source)
I have also installed IzPack, but the error keeps happening.
Does anyone know what is going on?
Thanks.
Óscar Diago Alonso
Desarrollador GIS / GIS Developer
Tel: +34 945131372 e-mail: mailto:oscar.diago@anonymised.com
Calle Pintor Clemente Arraiz, 3 Bajo 01008 Vitoria-Gasteiz
Geograma. Expertos en GeoInformación
[cid:image002.png@anonymised.com]
www.geograma.com<http://www.geograma.com/&gt;
De acuerdo con la LO 15/1999, de Protección de Datos, y la Ley 34/2002 (LSSICE), se informa que su dirección de correo electrónico figura en nuestros archivos, al objeto de mantener el contacto y remitirle publicidad e información empresarial sobre las actividades de Geograma, S.L. Si no desea recibir publicidad e información empresarial sobre las actividades de Geograma SL le rogamos que nos lo comunique a la siguiente dirección de correo electrónico: geograma@anonymised.com<mailto:geograma@anonymised.com> Podrá ejercer los derechos de acceso, cancelación, rectificación y oposición reconocidos por la LOPD mediante solicitud escrita y firmada a Geograma, S.L. a la siguiente dirección C/ Castillo de Eskibel, 2 Bajo de Vitoria (C.P. 01007), adjuntando en todo caso copia de su DNI. En caso de modificación de sus datos deberá notificarlo en la misma dirección, declinando toda responsabilidad para la empresa en caso de no hacerlo. Si no es Ud. el destinatario y ha recibido este mensaje por error, agradecemos que lo comunique inmediatamente al remitente sin difundir, almacenar o copiar su contenido.
(attachments)
Hi Oscar
I believe from my experience the windows installer is broken.
The application installs correctly but the installer gives you more options
via Next and if you click Next it either hangs or fails. If you click
Finish instead of Next then it exits happily. Unsure if this is exactly
what you are experiencing as I have learnt to avoid issues by clicking
Finish after it deploys.
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
Thanks for the answer. If I don’t click “Next” after installing, GeoNetwork works.
I thought it was going to be installed as a Windows Services, but I see is not the case.
Best regards.
Óscar Diago Alonso
Tel: +34 945131372 e-mail: mailto:oscar.diago@…1602…
[GEOGRAMA] [Certification_Badges-EDDA]
De acuerdo con la LO 15/1999, de Protección de Datos, y la Ley 34/2002 (LSSICE), se informa que su dirección de correo electrónico figura en nuestros archivos, al objeto de mantener el contacto y remitirle publicidad e información empresarial sobre las actividades de Geograma, S.L. Si no desea recibir publicidad e información empresarial sobre las actividades de Geograma SL le rogamos que nos lo comunique a la siguiente dirección de correo electrónico: geograma@...1602...<mailto:geograma@…1602…> Podrá ejercer los derechos de acceso, cancelación, rectificación y oposición reconocidos por la LOPD mediante solicitud escrita y firmada a Geograma, S.L. a la siguiente dirección C/ Castillo de Eskibel, 2 Bajo de Vitoria (C.P. 01007), adjuntando en todo caso copia de su DNI. En caso de modificación de sus datos deberá notificarlo en la misma dirección, declinando toda responsabilidad para la empresa en caso de no hacerlo. Si no es Ud. el destinatario y ha recibido este mensaje por error, agradecemos que lo comunique inmediatamente al remitente sin difundir, almacenar o copiar su contenido.
De: Luke [mailto:coolhandluka@…54…]
Enviado el: jueves, 22 de junio de 2017 7:41
Para: Oscar Diago Alonso <Oscar.Diago@...1602...>
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] Installation issue
Hi Oscar
The application installs correctly but the installer gives you more options via Next and if you click Next it either hangs or fails. If you click Finish instead of Next then it exits happily. Unsure if this is exactly what you are experiencing as I have learnt to avoid issues by clicking Finish after it deploys.
Luke Bassett
Melbourne Australia
(attachments)
