Hi Jean,
I haven’t installed it on OS X because my client doesn’t have it! They’re using Windows, so I’ve no choice.
The URL is http://localhost:8080/geonetwork/srv/en/main.home
Lawrence
Lawrence Moran
GIS Analyst
Brown & May Marine Ltd.
From: Jean Pommier (IGE) [mailto:jean.pommier@…474…]
Sent: 31 October 2013 13:41
To: Lawrence Moran
Cc: Jose Garcia; geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Installation problems, 2.10
Why wouldn't you try it on OS X ? I've got very small experience with OS X, but with linux, using the jar install file, it works pretty much out of the box.
Just to check, what is the complete URL you try to open ? It should start with localhost:8080. If not, that could simply be the issue... ;o)
Jean
2013/10/30 Lawrence Moran <LawrenceMoran@...1273...<mailto:LawrenceMoran@…1273…>>
Still the same problem! Though that doesn’t rule out permissions issues; I generally use a Mac and last time I regularly used Windows it was XP. I’m doing some reading up on Windows 7 and am finding there can be problems with permissions, but I’m struggling to get to the bottom of it. Hopefully I can, and it resolves this problem.
Lawrence Moran
GIS Analyst
Sent: 23 October 2013 13:32
To: Lawrence Moran
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hi
I see you installed in C:\Program Files (x86)\geonetwork
Please install outside of Program Files folder as GeoNetwork has some issues with permissions in that folder.
In windows i usually install the application in c:\programs\geonetwork to avoid this.
Jose García
On Wed, Oct 23, 2013 at 2:26 PM, Lawrence Moran <LawrenceMoran@...1273...<mailto:LawrenceMoran@…1273…><mailto:LawrenceMoran@…1273…>> wrote:
Thanks Jose,
I’ve checked the log file (attached) but nothing stands out to me as being a critical error.
I have checked the system requirements and have found nothing amiss there, so I’m at a loss.
Any further suggestions??
Lawrence
Lawrence Moran
GIS Analyst
From: Jose Garcia [mailto:jose.garcia@…444…<mailto:jose.garcia@…444…>]
Sent: 23 October 2013 12:46
To: Lawrence Moran
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net><mailto:geonetwork-users@lists.sourceforge.net>
Hi Lawrence
Check in the folder INSTALL_DIR/jetty/logs, log files should contain some information about the issue.
Jose García
On Wed, Oct 23, 2013 at 12:08 PM, Lawrence Moran <LawrenceMoran@...1273...<mailto:LawrenceMoran@…1273…><mailto:LawrenceMoran@…1273…>> wrote:
I'm new to GeoNetwork, though not to GIS, opensource etc. But I'm an analyst, rather than a technical computer person (my own computer is a Mac, and 99% of the time, stuff just works), so I may need to ask you to expand upon your responses!
I'm having difficulty installing GeoNetwork 2.10. I'm going through the process defined here<http://geonetwork-opensource.org/manuals/2.10.0/eng/users/quickstartguide/installing/index.html>, to install on my PC but having started the server I get the error:
'The requested URL /geonetwork/srv/en/main.home was not found on this server'
As the start-up script runs, I see a few warnings, such as the GDAL libs have not loaded, which I know in itself is not critical but could it be indicative of errors in the installation? Is there a log from the start-up script somewhere?
Has anyone any idea where to start in diagnosing the problem?
Thanks
Lawrence
Lawrence Moran
GIS Analyst
Progress Way
Mid Suffolk Business Park
Eye
Suffolk
IP23 7HU
T: 01379 870181
F: 01379 870673
A UK Registered Company No. 1788594
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net><mailto:GeoNetwork-users@lists.sourceforge.net>
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/> for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Android is increasing in popularity, but the open development platform that
developers love is also attractive to malware creators. Download this white
paper to learn more about secure code signing practices that can help keep
Android apps secure.
http://pubads.g.doubleclick.net/gampad/clk?id=65839951&iu=/4140/ostg.clktrk
