Hello,
Thanks very much for your answer. I’m using Linux but I’ll try to do the same, if someone has made it possible in Debian or Linux I would appreciate to know how.
I saw that one line of the conf was worker.worker1.port=8009, is that possible to run everything on port 80 or the servlet requires an exclusive port?
Felipe CostaStefano Giaccio sgiaccio@anonymised.com escreveu:
Here is a list of steps that should make GeoNetwork work on Apache2 and mod_jk, at least with Windows:
Download latest version of mod_jk 1.2 from http://tomcat.apache.org/download-connectors.cgi (mod_jk-apache-2.0.55.so or something like this)
Rename it mod_jk.so
Move it into Apache2/modules directory
Open Apache2/conf/httpd.conf in a text editor
Uncomment the following line:
#LoadModule rewrite_module modules/mod_rewrite.so
removing the leading #
- And add the following line at the end:
include conf/geonetwork.conf
Create the file conf/geonetwork.conf
Write the following text into it:
LoadModule jk_module modules/mod_jk.so
JkWorkersFile conf/workers.properties
JkLogFile logs/mod_jk.log
JkLogLevel error
JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
JkOptions +ForwardKeySize +ForwardURICompat -ForwardDirectories
JkMount /geonetwork/* worker1
JkRequestLogFormat “%w %V %T”
RewriteEngine on
RewriteRule ^/geonetwork$ /geonetwork/ [R]
- Create the file conf/workers.properties
- Write the following text into it:
Define 1 real worker using ajp13
worker.list=worker1
Set properties for worker1 (ajp13)
worker.worker1.type=ajp13
worker.worker1.host=localhost
worker.worker1.lbfactor=50
worker.worker1.cachesize=10
worker.worker1.cache_timeout=600
worker.worker1.socket_keepalive=1
worker.worker1.recycle_timeout=300
- Restart Apache 2
Let me know how it goes!
Bye
StefanoOn Aug 2, 2006, at 4:23 PM, Felipe Costa wrote:
Hello List,
Has someone ever installed Geonetwork under Apache2? Let me explain…
I have already installed geonetwork with Tomcat and Jetty, but now I want to run with Apache2 and Geonetwork as a servlet with mod_jk connector.
Any ideas of how to do that?
Thanks in advance,
Felipe Costa"Se o Senhor não constrói a casa, em vão trabalham os construtores” (Sl 127,1)
Você quer respostas para suas perguntas? Ou você sabe muito e quer compartilhar seu conhecimento? Experimente o Yahoo! Respostas!
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys – and earn cash
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork"Se o Senhor não constrói a casa, em vão trabalham os construtores” (Sl 127,1)
Yahoo! Search
Música para ver e ouvir: You’re Beautiful, do James Blunt
O Yahoo! está de cara nova. Venha conferir!
