[GeoNetwork-users] Installer hanging on Windows 10
Dear All,
I decided to go ahead and install GeoNetwork on my notebook. I downloaded
the latest Jar installer, however the installer seams to run in an infinite
loop after unpacking the files.
Is there anything I should do before installing? UAC is off and I do not
have any anti-virus on when installing the software.
The installer stopped here:
Best regards.
Lyes Mokraoui,
(attachments)
I don't know what could be happening. I installed a Windows 10 VM image
from Microsoft web [1]. Then I've downloaded and installed OpenJDK 8 from
AdoptOpenJDK webpage [2]. Finally I've downloaded
geonetwork-install-3.10.1-0.jar from SourceForge and I double clicked it.
The installer has started and after selecting a target directory where I
have write permissions the installer has finished more or less
successfully. Last page of the installer is empty as you show in your
screenshot, but it has finished and you can click Quit or kill the
installer if it doesn't finish. The only thing missing are the shortcut
creation step.
If you go to the installation directory, then bin and run startup.bat
script GeoNetwork should start and you should be able to access it at
http://localhost:8080/geonetwork
[1] https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
[2] https://adoptopenjdk.net/releases.html
On Tue, Mar 3, 2020 at 10:50 AM Lyes Mokraoui <lyes.mokraoui@anonymised.com> wrote:
Dear All,
Juan Luis.
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Juan,
I have accessed the bat file and the service seams to be running. The shortcuts are not installed though.
When I try to view the page in http://localhost:8080 Jetty returns some errors. I will open a new thread on this issue.
Thank you,
Best regards.
Lyes
From: Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com>
Sent: Tuesday, March 3, 2020 7:55 PM
To: Lyes Mokraoui <lyes.mokraoui@anonymised.com>
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Installer hanging on Windows 10
I don't know what could be happening. I installed a Windows 10 VM image from Microsoft web [1]. Then I've downloaded and installed OpenJDK 8 from AdoptOpenJDK webpage [2]. Finally I've downloaded geonetwork-install-3.10.1-0.jar from SourceForge and I double clicked it. The installer has started and after selecting a target directory where I have write permissions the installer has finished more or less successfully. Last page of the installer is empty as you show in your screenshot, but it has finished and you can click Quit or kill the installer if it doesn't finish. The only thing missing are the shortcut creation step.
If you go to the installation directory, then bin and run startup.bat script GeoNetwork should start and you should be able to access it at http://localhost:8080/geonetwork
On Tue, Mar 3, 2020 at 10:50 AM Lyes Mokraoui <lyes.mokraoui@anonymised.com <mailto:lyes.mokraoui@anonymised.com> > wrote:
Dear All,
Juan Luis.
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: <tel:+31318416664> +31 (0)318 416664
Please consider the environment before printing this email.
