Hello,
I am testing whether geonetwork fits into our organization. We are working
with ESRI products. All our metadata is stored as xml in MS SQL Server 2005.
The first thing I came across is about the installation. If I understood
right I need to install a jdbc driver to access our MS SQL Server. Where can
I find detailed instructions to do that?
So far I have downloaded the driver and copied sqljdbc4.jar into this
directory:
C:\Program Files\geonetwork\web\geonetwork\WEB-INF\lib
Then in GAST:
JDBC Driver: sqljdbc4.jar
URL: jdbc:sqlserver://myserver\mydbname
Username: myusername
Password: mypassword
Am I in the right path? Should I also go to control panel / ODBC Data Source
Administrator and add the driver from there?
Thank you!
Manolo
View this message in context: http://n2.nabble.com/Installing-jdbc-driver-to-access-MS-SQL-2005-tp3938371p3938371.html
