[GeoNetwork-users] Intermap and EPSG other then 4326
   Hello,
   I'm new with geonetwork and have a question. Is it possible to change the EPSG-Code? I need to use different EPSG-Codes and want to change the EPSG in the viewer. The WMS-Services support the EPSG-Codes I want to use. So InterMap do not have to transform on the fly, but have to perform the getMap-Request wit the right EPSG-Code.
   Regards, David Arndt.
geoinformation+planung
reichert+partner ingenieure
gölzstr. 22 72072 tübingen
fon: +49 (0)7071-407360
fax: +49 (0)7071-407361
arndt@anonymised.com
geoinformation+planung - reichert+partner | http://www.geoinformation-planung.de
Yes, it is hardcoded in the Java sources. You find it in:
src/org/wfp/vam/intermap/kernel/map/mapServices/wms/WmsService.java
Ciao,
Jeroen
On Oct 26, 2007, at 12:04 PM, David Arndt wrote:
   Hello,
arndt@...306...
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hello,
I'm beginning with geonetwork (v2.2), and I would like to adapt it for a
research departement in a national parc in the UK... I have a problem with
the datum employed in geonetwork since my map are 'flatened ' by the
projection.
I tried to change the EPSG code in the WmsService java file, and to
re-compile (with ant)... but after that, nothing appears in the map
viewer.Moreover when I export the context files from Intermap, the previous
EPSG is always indicated (4326) like this:
<ViewContext version="1.1.0" id="14f53594-00e5-4bb4-ac7a-0d3769519e4f">
   <General>
      <Title>Intermap context 14f53594-00e5-4bb4-ac7a-0d3769519e4f</Title>
      <BoundingBox SRS="EPSG:4326" minx="-180.0" miny="-114.19766"
maxx="180.0" maxy="114.19766"/>
Is there an other place where I have to change this EPSG code?
Thanks
Eliane
Jeroen Ticheler-3 wrote:
Ciao,
Jeroen
   Hello,
browser.
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
View this message in context: http://www.nabble.com/Intermap-and-EPSG-other-then-4326-tp13424255p18524907.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
