Hi All.
I have some problem with intermap when I tryi to show a WMS contains
multipolygon data.
When I try to do a Interactive map with point o such like this there
are no problem with intermap but, if the data in the PostGis database
are Mulipolygon, the intermap not recognize the layer and in the
metadata is impossible to show a interactive map.
Any suggestions about this problems with intermap???
Thank you!!!!
Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Hi Francesco,
This should make no difference to intermap. It will not know whether it is a polygon or multipolygon type by the time it gets to the WMS client. Are you sure that you can see this layer properly in Geoserver (or whatever WMS server) you may be using? Have you defined a proper default style for the layer?
Also, any stack traces/log files would be useful to post.
Best regards,
Jason
Jason P. Pickering
Consultant
WHO/Ministry of Health Zambia
email: pickeringj@anonymised.com
tel: +260968395190
From: Francesco D'Amore [mailto:francesco.damore@anonymised.com]
Sent: Tue 2009-09-08 22:13
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Intermap and visualization
Hi All.
multipolygon data.
Thank you!!!!
Francesco D'Amore
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
Ciao Francesco,
2009/9/8 Francesco D'Amore <francesco.damore@anonymised.com>:
Hi All.
multipolygon data.
Does the wms service for that layer work with another client?
Luca
Dott. Ing. Luca Casagrande
Open Source GIS analyst and developer
Gfosservices SA
http://www.gfosservices.com
skype: lucacasagrande
This is the problem..... I tried the WMS layer with other clients for
WMS, such as QuantumGIS and every layer showed right.
In Intermap, if a use it alone, I can put the WMS server for
discovering WMS layer.... but only layer with POINT was detected.
May be an error in Geoserver definition......... I will check.
Thank you.
2009/9/9 Luca Casagrande <luca.casagrande@anonymised.com>:
Ciao Francesco,
Hi All.
multipolygon data.
Luca
Gfosservices SA
Francesco D'Amore
I think that the problems is related to Geoserver with a REST
plugin..... Geonetwork works fine.
Thank you for help.
2009/9/9 Francesco D'Amore <francesco.damore@anonymised.com>:
Thank you.
Ciao Francesco,
Hi All.
multipolygon data.
Luca
Gfosservices SA
Francesco D'Amore
Francesco D'Amore
