[GeoNetwork-users] Intermap connects problems
Some time I have connections problems in Intermap...... GN don't show
the map in left up side becouse intermap doesn't work.
The logs in Tomcat logs are:
imagePath: /usr/share/apache-tomcat-6.0.18/applications/geonetwork/web/intermap/tmp/temp108583709813938370.tmp
Recoverable error
  XTRE0540: Ambiguous rule match for /
Matches both "document-node()" on line 6 of
  file:/usr/share/apache-tomcat-6.0.18/applications/geonetwork/web/intermap/xsl/index.xsl
and "document-node()" on line 5 of
  file:/usr/share/apache-tomcat-6.0.18/applications/geonetwork/web/intermap/xsl/index-embedded.xsl
May be some things wrong or some bug fix needed???
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
