[GeoNetwork-users] Intermap does not display a map
Dear all,
I've still trouble with my GN installation, more precisely no map is loaded in intermap.
I found some threads in the nabble forum which focus the problem but non of the suggestions solved my problem.
I installed GN2.2 with jetty on a ubuntu server as root. When I start GeoNetwork, Intermap starts loading but no map is shown. I checked 'http://myIP:8080/geoserver/’ but geoserver doesn't work:
HTTP ERROR: 404/geoserver/ Not FoundWhen I look into the intermap.log there I found:
<imgUrl>/usr/local/geonetwork/web/intermap/tmp//null</imgUrl>
The requested image is null?! Maybe rights to read/write files into the tmp-dir are required. So I changed the rights for \ ...\geonetwork\web for 'www-data' (what is the webserver) and also for 'root' and gave full rights to read/write/access, but nothing changed.
What could solve the problem?
Christian
I'm having the same problem right now : no map shown in the intermap window
and <imgUrl>/usr/local/geonetwork/web/intermap/tmp//null</imgUrl> in the
log.
Did you solve it ?
Do anyone have an idea ?
Thanks
Jean
N'imprimez ce message qu'en cas de nécessité. Soyons éco-responsables !
Donnez une nouvelle dimension à vos données…
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Port : +33 6 09 23 21 36
Skype : igejean
Information Géographique et Environnement
12 rue Arnaud Vidal
31000 Toulouse
France
Tel : +33 5 61 86 81 49
Fax : +33 5 61 86 09 23
Mail : contact@anonymised.com
Site web : www.ige.fr <http://wwww.ige.fr>
*L'actualité d'IGE sur RSS : *http://www.ige.fr/actualites/rss.php
*Localisez IGE dans WorldWind : *
worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
2009/1/26 Christian Gadge <christian.gadge@anonymised.com>
Dear all,
in intermap.
I found:
Christian
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
GeoNetwork-users mailing list
When requiring localhost:8080/intermap, i get a sun.awt.X11.X11Toolkit
NoClassDefFoundError
I guess it should be either a rights issue, or a runlevel issue, tomcat
trying to access to X11 library at a runlevel it is not allowed to (as a
server, it shall not depend on X11, should it ?)
Does it give any idea to someone ?
2009/3/12 Christian Gadge <christian.gadge@anonymised.com>
Hello Jean,
no so far I didn' solve the problem. It appears since I implemented GN2.2.
The former installation of GN2.1 which I installed on a linux machine (local
folder) works fine.
Now I tried to run as root... Intermap doesn't work or rather geoserver.
That's why I assume that there has to be set correct rights. But the
installation of GN2.2 on different machines in local or system folder
results the same problem.
So far I'm still interested how it could be solved...
Let's rely on the mailing list.
Cordialement,
Christian
----- Ursprüngliche Nachricht -----
Von: "Jean Pommier (IGE)" <jean.pommier@anonymised.com>
Datum: Donnerstag, 12. März 2009, 9:58
Betreff: Re: [GeoNetwork-users] Intermap does not display a map
An: Christian Gadge <christian.gadge@anonymised.com>
Cc: geonetwork-users <geonetwork-users@lists.sourceforge.net>
> Hi,
window and <imgUrl>/usr/local/geonetwork/web/intermap/tmp//null</imgUrl> in
the log.
> Did you solve it ?
> Thanks
> Jean
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
> Dear all,
loaded in intermap.
there I found:
> Regards,
> Christian
Christian Gadge
Projektinitiative 'Risk Habitat Megacity'
Datenmanagement /
Department Stadtökologie , Umweltplanung und Verkehr
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Permoserstraße 15 I 04318 Leipzig
Telefon +49 (0)341 235-1730
Telefax +49 (0)341 235-1834
http://www.ufz.de
Das UFZ hat einen neuen Namen: Helmholtz-Zentrum für Umweltforschung GmbH -
UFZ
Sitz der Gesellschaft: Leipzig
Registergericht: Amtsgericht Leipzig
Handelsregister Nr. B 4703
Vorsitzender des Aufsichtsrats: MinDirig Hartmut F. Grübel
Wissenschaftlicher Geschäftsführer: Prof. Dr. Georg Teutsch
Administrativer Geschäftsführer: Dr. Andreas Schmidt
