[GeoNetwork-users] InterMap "Object Expected"Exception
Hi All,
          I am using the GeoNetworks 2.1.0 with inbuilt Intermap using the
Jetty Server,although i able to connect to the WMS Server as well as can add
the layer but the main problem coming up is that i unable to use Zoomin or
Zoom out,Pan or any kind Mapping control and it use to give error Object
Expected -Line 85 Char2
http://localhost:8080/intermap/srv/en/main?width=200&height=100 and in the
Webpage i use to get exception error Exception-"Object Expected". How to
solve this issue or is it bug with the ?Intermap integrated with
GeoNetworks.
Thks
Max
View this message in context: http://www.nabble.com/InterMap-"Object-Expected"Exception-tp18566864p18566864.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
