Hello all,
i would like to set visible or unvisible a layer defined in the
mapservers.xml file. Is there any tag for rendering a layer or not ?
For example, the layer named tdc set to unvisible but present on the big
map layers.
like this :
<mapContexts>
<default name="Layers for default map -- DUMMY NAME:not used">
<server url="http://sig.dev.gov.pf:8080/geoserver/wms" type="2" >
<layer name="SIT:Monde_JPG24bit_ZEEPF"></layer>
</server>
<server
url="http://www.tefenua.gov.pf/wmsconnector/com.esri.wms.Esrimap/PF_FOND" type="2" >
<layer name="fond_bathy_pg" />
<layer name="tdc" />
<layer name="mosaique" />
</server>
</default>
</mapContexts>
