[GeoNetwork-users] international standards
Dear all,
I tried alot to implement the Geonetwork-Ebrim and I couldn't manage that. I posted some questions to the community and received nothing. So, now I am disappointed and now just have one general question,
why there is no interested from Geonetwork to extend it and the metadata to use ebrim profile of CSW?Is there any technical issue? I just want to know that is it worth my effort?
Best regardsMani
Hi
In 2009 was implemented a project to support ebrim, available in
https://sourceforge.net/p/geonetwork/code/HEAD/tree/sandbox/3.0.x/. It
implements also a ebRim registry, but the code was done for GeoNetwork 2.6
and for sure it's not supporting the latest spec from ebrim.
It's really outdated and to implement in current 3.4 version I think should
be review the architecture (for example to integrate with existing
solutions that implement ebRim registry instead of using a custom
implementation).
But afaik other catalogues like pyCSW or Deegree use a simpler solution not
implementing a ebRim registry and using some xslt to create the ebRim
output in CSW from the metadata stored in iso19139. I'm not an expert in
this, but I think this can be a good approach to implement in GeoNetwork
and probably can be reused most probably the current xslt used in the
pointed projects, instead of implementing also the ebRim registry.
Jose García
On Fri, Apr 20, 2018 at 2:12 PM, mane moshref via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
Best regardsMani
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
'el que no llora....
-----Mensaje original-----
De: Jose Garcia [mailto:jose.garcia@…444…]
Enviado el: viernes, 20 de abril de 2018 15:44
Para: mane moshref <many_yammy@...8...>
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] international standards
Hi
In 2009 was implemented a project to support ebrim, available in https://sourceforge.net/p/geonetwork/code/HEAD/tree/sandbox/3.0.x/. It implements also a ebRim registry, but the code was done for GeoNetwork 2.6 and for sure it's not supporting the latest spec from ebrim.
It's really outdated and to implement in current 3.4 version I think should be review the architecture (for example to integrate with existing solutions that implement ebRim registry instead of using a custom implementation).
But afaik other catalogues like pyCSW or Deegree use a simpler solution not implementing a ebRim registry and using some xslt to create the ebRim output in CSW from the metadata stored in iso19139. I'm not an expert in this, but I think this can be a good approach to implement in GeoNetwork and probably can be reused most probably the current xslt used in the pointed projects, instead of implementing also the ebRim registry.
Jose García
On Fri, Apr 20, 2018 at 2:12 PM, mane moshref via GeoNetwork-users < geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
I am disappointed and now just have one general question, why there is
Best regardsMani
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García <http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the environment before printing this email.*
Check out the vibrant tech community on one of the world's most engaging tech sites, Slashdot.org! http://sdm.link/slashdot _______________________________________________
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
