I'm using geonework 3.0.2.0 and can't seem to get the "When" search working correctly. It appears that the Time Extent of the meta data is never taken into account and only the changeDate is being searched.
Is it possible to make the search look at the Time Extent at all? What would be required to implement this from the user interface?
This is what I tried:
I imported the sample meta data:
Geographic information - Metadata (ISO/TS 19139:2007) ISO19139 metadata standard.
One of the records is the following:
Hydrological Basins in Africa (Sample record, please remove!)
With a Time Extent From 2006-01-01 until 2008-01-08
It has a changeDate of: "2007-11-06T12:13:00"
So doing some searches shows only changedDate is taken into account:
changedate in range:
http://localhost:8080/geonetwork/srv/eng/q?_content_type=json&dateFrom=2007-11-02&dateTo=2007-11-07&fast=index&from=1&sortBy=relevance&to=20
2 results.
dateTo is before changeDate:
http://localhost:8080/geonetwork/srv/eng/q?_content_type=json&dateFrom=2007-11-02&dateTo=2007-11-05&fast=index&from=1&sortBy=relevance&to=20
0 results.
dateFrom is after changeDate:
http://localhost:8080/geonetwork/srv/eng/q?_content_type=json&dateFrom=2007-11-07&dateTo=2007-11-08&fast=index&from=1&sortBy=relevance&to=20
Rudie.
DISCLAIMER: This message is intended exclusively for the addressee(s) and may contain confidential and privileged information. If you are not the intended recipient please notify the sender immediately and destroy this message. Unauthorized use, disclosure or copying of this message is strictly prohibited. The foundation 'Stichting Deltares', which has its seat at Delft, The Netherlands, Commercial Registration Number 41146461, is not liable in any way whatsoever for consequences and/or damages resulting from the improper, incomplete and untimely dispatch, receipt and/or content of this e-mail.
Check the github issue
https://github.com/geonetwork/core-geonetwork/issues/1313
Cheers.
Francois
2015-12-01 10:22 GMT+01:00 Rudie Ekkelenkamp <Rudie.Ekkelenkamp@anonymised.com>
standard.
2 results.
0 results.
Rudie.
of this e-mail.
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple
OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741911&iu=/4140
GeoNetwork-users mailing list
