[GeoNetwork-users] Is it possible to stop GN (2.6.3) from changing the uploaded metadata record when responding to a CSW request?
I've uploaded some service metadata records into geonetwork which includes
various srv:operatesOn elements in the following format (eg specifying
uuidef xlink:href and xlink:title attributes):
<srv:operatesOn xlink:title="BGS.1M.surface.GeologicUnit"
xlink:href="http://ogcdev.bgs.ac.uk/geonetwork/srv/en/csw?SERVICE=CSW&amp;amp;REQUEST=GetRecordById&amp;amp;ID=9df8df52-d788-37a8-e044-0003ba9b0d98&amp;amp;elementSetName=full&amp;amp;OutputSchema=http://www.isotc211.org/2005/gmd&amp;amp;&quot;
uuidref="9df8df52-d788-37a8-e044-0003ba9b0d98"/>
When I try to harvest these records using CSW eg as:
http://ogcdev.bgs.ac.uk/geonetwork/srv/en/csw?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetRecordById&ID=a0a82d76-657c-2a78-e044-0003ba9b0d98&elementSetName=full&OutputSchema=http://www.isotc211.org/2005/gmd&
The record returned is not the same as I have uploaded it. Instead GN
substitutes the full gmd:MD_Metadata record for the layer-dataset, and
strips out the xlink:href and xlink:title attributes.
How do I force the CSW response to be my uploaded record?
Thanks
James
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-stop-GN-2-6-3-from-changing-the-uploaded-metadata-record-when-responding-to-a-CSW--tp6328258p6328258.html
Hello,
2011/5/3 nmtoken <jpass@anonymised.com>:
You probably have the XLink resolver turned on. Try to turn it off
from the administration settings panel.
HTH.
Francois
Thanks
James
WhatsUp Gold - Download Free Network Management Software
The most intuitive, comprehensive, and cost-effective network
management toolset available today. Delivers lowest initial
acquisition cost and overall TCO of any competing solution.
http://p.sf.net/sfu/whatsupgold-sd
GeoNetwork-users mailing list
Many thanks Francois that's fixed it.
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
