Hi All,
It appears that the GeoNetwork that we have setup often stops working. Maybe it is a configuration or a settling in issue. I don't know but what I would like to do is run a script that tells me if GeoNetwork is still running and if not then start up the tomcat instance for GeoNetwork.
I can do this by listing the processes and checking if there is one running for GN. If not then I can run the GN start-up script.
I could also store the PID in a file and then check if that file has content. Etc.
Is there a file that contains the PID for the GN tomcat instance? If so where and what is the name of that file?
Thanks.
John Hockaday
Spatial Standards Group (OSDM)
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
http://www.osdm.gov.au/
john.hockaday\@osdm.gov.au
