[GeoNetwork-users] Is there a way to convert FGDC to ISO 19139?
   Thank You Very Much. I found the the tool in ArcGIS 9.3, But I couldn't
convert some information to ISO 19139.
   Best Regards.
   Rajah.
On Sat, Jul 25, 2009 at 9:53 PM, Todd Fagin (via Nabble) <
ml-user+137646-1075933843@anonymised.com<ml-user%2B137646-1075933843@anonymised.com>
wrote:
Greetings,
I was searching for a related topic and came across your post. I do not
know if you have found an answer yet, but I will supply you one nonetheless.
If you happen to have access to ArcGIS 9.3, ArcToolbox has a metadata
translator that enables conversion from FGDC to ISO 19139.
Also, the FGDC is currently in the process of developing a metadata
conversion tool. To the best of my knowledge, it is not available yet.
Good luck,
Todd
View message @
http://n2.nabble.com/Is-there-a-way-to-convert-FGDC-to-ISO-19139--tp3249364p3325868.html
To unsubscribe from Is there a way to convert FGDC to ISO 19139?, click
here< (link removed) >.
View this message in context: http://n2.nabble.com/Is-there-a-way-to-convert-FGDC-to-ISO-19139--tp3249364p3331735.html
