[GeoNetwork-users] iso19139.anzlic schema_plugin
I am attempting to add the iso19139.anzlic schema-plugin for
Geonetwork 3.0.3 from
the metadata 101 respository on GitHub.
I have copied the schema-plugins files into the schema_plugins directory
and restarted the server. Geonetwork loads and the ANZLIC schema is
available in the GUI. Loading the templates and the samples appears to
work fine
too.
But I can't create a new record using any template. The form fields for the
template don't appear in the GUI.
Is the schema-plugin working correctly? Do I need to build geonetwork
instead of deploying from the .WAR file?
Thanks for your help.
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient, please
delete it and notify the sender. Views expressed in this message are those
of the individual sender, and are not necessarily the views of their
organisation.
