I just installed 2.10 to test and get this same issue. Loads application but after I add a test metadata record I get a successful 'sample metadata record added' but when I click on "Home", get the exact error Eleni reported last week. After it throws the error I cannot open GN 2.10 at all even after a stop/restart.
I am just installing and running everything as 'vanilla' on my localhost with no changes at this point.
I haven't seen anyone respond to her with a fix so am throwing this out there again -- Any idea what is causing this and a resolution?
Kathy
-----Original Message-----
From: Eleni Gadolou [mailto:elenigadolou@anonymised.com]
Sent: Thursday, June 27, 2013 5:28 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] question
Hello,
When I tried to insert metadata (an xml file from arcgis 10) into Geonetwork an error occured. This error comes up every time I try to login.
The error is:
XPathException : Template iso19139Brief has not been defined
Could you please help me with a solution?
Thank you in advanced,
Eleni
Hi Kathy,
2013/7/2 Kathy Koch <kkoch@anonymised.com>:
Could you provide more info from geonetwork.log and the platform ? May
this be related to an installation on windows with a directory name
containing space ?
Cheers.
Francois
Kathy
Hello,
The error is:
Eleni
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
GeoNetwork-users mailing list
